11-06-2007, 11:45 PM | #1 |
Pebble Pounder Join Date: Oct 2007 Location: Fullerton
| drive shaft trouble
i have A rustler trans in my bruiser and iv been running it for about a month and know all of a sudden the drive shaft for the front axel keeps popping off on the trans end. cant figure out why ive changed the drive shaft and the universal on the trans and it just keeps popping off and sugestions. i have an 55t integy 15p 87s. has anyone else had this prolem with these. |
11-07-2007, 01:46 AM | #2 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Get the newer style outputs that have the pin through design. Then buy screw pins. The old set screws are just not up to task. Once it starts falling off, the diff outdrives start to wear grooves so it fall off a lot more often. These for the trans http://www.rcslot.com/mm5/merchant.m...w=&range_high= Buy this for the through pins. http://www.rcslot.com/mm5/merchant.m...w=&range_high= |
11-07-2007, 07:44 AM | #3 |
i allready have those long pins the problem is that the drive shaft id popping off were it attaches to the 4 spiked at the joint |
11-07-2007, 09:12 AM | #4 |
Rock Crawler Join Date: Feb 2006 Location: Warner Robins
The drive shaft pops off the universal? What shafts are you running? Post up a pic. |
11-07-2007, 02:17 PM | #5 |
Rock Stacker Join Date: Jul 2006 Location: 2" behind my eyes
i had this problem for a while. when i started using steel yokes on both ends it was less often, then i lowered my rigs ride height and it hasn't happened since. if your driveline angle is too steep, it'll pop the shaft off the yoke. hope this helps
