11-10-2007, 10:30 PM | #1 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
| Steering linkages
I'm setting up my steering links and it's not quite working out. So what I'm thinking about is using a HD Kimbrough servo saver and running a link to each knuckle instead of a cross link from knuckle to knuckle and from servo to knuckle. Anybody tried this, thoughts, pros or cons? |
11-10-2007, 10:39 PM | #2 |
Quarry Creeper Join Date: Aug 2006 Location: Farmerville
If you were to get it just right it would probably work very well. I have never tried it though and Im sure someone will chime in on it.
11-10-2007, 10:41 PM | #3 |
Plus my servos output isn't centered in between the knuckles and I'm not about to remake my servo mount/bracket.
11-11-2007, 09:56 PM | #4 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
Your tires wouldn't steer the same degree side to side.
11-11-2007, 10:04 PM | #5 |
I'll be making a new servo mount and reworking my whole servo/steering/link geometry. I'm gonna center the output between the knuckles, use the Kimbrough HD SS and get some 4mm turnbuckles and RC4WD M4 rod ends and reverse thread rod ends.
