11-11-2007, 08:34 PM | #1 |
Pebble Pounder Join Date: Feb 2006 Location: Winston-Salem
| Suspension questions
My truck has alot of rear steer (flex steer). It also slides the frontend sideways when going up hills (if off camber slightly), I know some of this could be from the Losi LST tires lack of lateral traction, but it seems it is mainly from the back right tire pulling "too" much, and walking up under the truck. I may be answering my own question here, but I am thinking about the only thing I am going to be able to do is stand the shocks up more to reduce flex, therefore reducing flex steer. It is also pretty bad about flipping over backwards (too much weight transfer to rear I guess), how could I fix that? The truck has wheel weights in the front, and the battery is a little higher than I would like, but I hae a 1/4 scale servo and there isn't really any room on the axle. |
