11-14-2007, 04:54 AM | #1 |
Pebble Pounder Join Date: Aug 2006 Location: in "Joisey"
| DIG QUESTION: ???4wd/REAR FREE WHEEL/Rear Locked???
I've been trying to read up on Dig setups (for my AX10) and have found that there can be 3 positions (if desired) depending on design... 4wd, Rear Free wheel & Rear Lock Would someone please explain the benefit of needing/using the "Free Wheel" position? Thanks in Advance, RCholic |
11-14-2007, 06:05 AM | #2 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
There have been times where I needed to use the front tires to help pull the front over an obstacle. 4wd it tries to go over backwards, 2WD locked it might not want to drag the rear wheels so it would be freewheel until the front gets a bite then 4WD. Granted, it seems to be more useful to have the rear locked as opposed to freewheel but there are times when freewheel is used as well. This is just my .02, but I like having the choice between the two. |
11-14-2007, 12:12 PM | #3 | |
Quarry Creeper Join Date: Jul 2006 Location: PDX
I had my R2D set up for 4wd and rear locked at first and then saw where it helped Eric113 make a couple of climbs that I couldn't. Went home modded the DX3 with a parallel on-off-on 3rd position switch and am very pleased with the results. | |
11-14-2007, 08:11 PM | #4 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Uh, the national champ only uses free wheel.
11-14-2007, 08:42 PM | #5 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
| True, but he's also a better driver than any of us. I, too, use a 3 position dig. Sometimes you want to lock or drag the rear tires when going down a steep drop, or when digging around a tight corner. The freewheel dig helps when climbing a steep ledge, and also helps out when you want to settle your suspension if it gets bound up. It's all personal preference, try both and decide for yourself. |
