05-06-2005, 09:20 PM | #1 |
Rock Stacker Join Date: Mar 2005 Location: planet earth
| local shops suck.
Any one here on RCC willing to help out? i need my gd-6 turned down to accept the proper size pinion. All the local shops want a arm and other body parts to do anything and Im not able or willing to come up with the cash they want per hr to do the lathe work. If there si any one willing to help please lmk. |
05-06-2005, 09:42 PM | #2 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
get me the shaft and I can do it at my buddies. I'll be going over there next week. Where are you at?
05-07-2005, 11:58 AM | #3 |
Newbie Join Date: Jan 2005 Location: Gold Bar, WA
I can also do that too. The machinists at my F/T job let me use their small lathe.
05-07-2005, 01:59 PM | #4 |
Pebble Pounder Join Date: Aug 2004 Location: orange county n.y. , building the hydro crawler
No lathe is needed. Just hook up the motor and run it while using a file pressed against the shaft. Works perfectly, just be careful and check every few seconds so you dont go to small. It does not take long at all to do.
05-07-2005, 03:00 PM | #5 |
Rock Crawler Join Date: Feb 2004 Location: The Gay NorthWest
i live in washington and can do it for free.... if you cant get anyone else to do it...
05-10-2005, 08:12 AM | #6 |
Rock Stacker Join Date: Apr 2005 Location: Tucson
If you don't mind me asking, what is the output shaft size on it now?
05-10-2005, 08:23 AM | #7 | |
It is 3/16", you can either turn down the shaft or drill out the pinion. The case also needs a little modification too. The front bearing housing is too thick, I turned that down a little too to make it work in my twin force. | |
05-10-2005, 08:24 AM | #8 |
Quarry Creeper Join Date: Feb 2004 Location: Mountain State!
Just bore out your pinion gear, it will keep the drivetrain stronger that way!!
05-10-2005, 09:42 AM | #9 |
Quarry Creeper Join Date: Jan 2005 Location: Carlisle, KY
I just ended up drilling out an 18 tooth pinion. It works great...
