Thread: wish bone or links
Old 12-31-2007, 04:02 PM   #1
Default wish bone or links
I posted somewhat the same question in the maxx forums here but I don't think there's as much traffic there as there is here, so maybe someone here can help me out. I'm in the process of building a maxx based crawler (tube chassis) and have a question. which would be better or what are the advantages/ disadvantages to wishbone upper links as opposed to individual links. Does one set up do something the other won't? my set up will have double triangulated links if I go the individual link way
allgm1 is offline   Reply With Quote
Old 12-31-2007, 04:13 PM   #2
The good thing about a wishbone(3-link?) would be that the axle steer would be less, meaning the axle wont move from side to side as much, but you might suffer in the articulation department.
With a good setup on a 4-link, you can eliminate all of those issues.
2JSC is offline   Reply With Quote
Old 12-31-2007, 04:22 PM   #3
Mmm NO! you don't know what axle steer is. You are talking lateral movement.
A triangulated 4 link is the best way to reduce axle steer and roll center.
A three link doesn't reduce articulation one bit.
Build wich ever one you want. You can get either to work very well.
Cole82 is offline   Reply With Quote
Old 12-31-2007, 04:27 PM   #4
Old 12-31-2007, 04:40 PM   #5
Here are 206 posts for you to brush up on your suspension knowledge.
Anti Squat and Suspension Tech
Old 12-31-2007, 08:30 PM   #6
Picky Fab'r/Acetal Junky
Offroader5's Avatar
He's right...a 3 link doesn't hinder articulation in the least...as long as it's designed correctly
Offroader5 is offline   Reply With Quote
Old 01-02-2008, 12:50 AM   #7
Really a wishbone is still a four link..there are still four links...one just has a combined mounting point. Three link is three links and a panhard that prevents latteral movement...usually done for clearance issues...like a gas tank not making a four link possible. Either one is gonna work if it's done right...do what's easiest for you with what you have.
miller is offline   Reply With Quote
Old 01-02-2008, 03:32 PM   #8
If it's a wishbone 3 link it's not four links.;)
Example not my work
Old 01-02-2008, 05:03 PM   #9
my thoughts were to use a wishbone set-up and mount a battery pack on it, cuz with a locked out maxx a arm set-up there isn't a whole lot of room on the axle
Old 01-02-2008, 05:24 PM   #10
Offroader5's Avatar
Oh, horse pucky If you use a saddle pack, you could easily fit 3 or 4 2/3A cells on each side of the center diff right on top of the upper control arm. All kinds of room up there
Old 01-02-2008, 06:03 PM   #11
What he said lots of room.
Get rid of the servo saver. You will have a hard time turning the tires with it on there.
Old 01-02-2008, 06:12 PM   #12
Example not my work
That three link with wishbone is going to work the exact same way as a four link...so again a wishbone three link is esentially a four link with the same mounting point on one end. That's what I'm saying...you're not going to have a noticeable difference in performance with a wishbone 3link or a 4link if the mounts are in the same spot...so if you don't have room to mount links side by side then do a wishbone, it's not going to perform any better or worse.
This is a three link with panhard that is very different from a four link.
http://www.trail-gear.com/trail-link.html
Old 01-02-2008, 06:51 PM   #13
Offroader5's Avatar
If you really want to get picky...the one you posted is a 4 link. the panhard/track bar is the 4th link. The front of say a Jeep is a 5 link because it has 4 separate axle links and then also a track bar.:-P
Your point is valid though...no real difference if they are set up the same geometrically.
Old 01-02-2008, 10:30 PM   #14
Old 01-03-2008, 10:09 AM   #15
toy4crawlin's Avatar
Trianglated 4 link, no axle steer, if set up correctly
3 link with panhard is getting popular but I don't think it would work well with a max while still using the a arms
my first max I put batteries like this 1st pic
2nd pic
then after breaking axles and being to wide I revised the whole rig & narrowed it all and put batteries behind the axle because of limited steering link space
toy4crawlin is offline   Reply With Quote
