Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: ...How to build a crawler Tutorial
Old 05-21-2005, 11:09 AM   #1
Default ...How to build a crawler Tutorial
I thought of making a FREEWEBS site
to show how to build your own custom
crawler. Hopefully this helps out those
not so fortunate on Fab skills....
http://www.freewebs.com/rockrigs/index.htm
Come check it out!!
Torredo is offline   Reply With Quote
Old 05-21-2005, 11:24 AM   #2
how much did this little clod project cost you w/o electronics?
Eclipse is offline   Reply With Quote
Old 05-21-2005, 12:23 PM   #3
Materials included:
3mm threadrod x8 1' lengths @ Approx 2.00ea.
Approx a 6"x10" sheet of WELD 16g18 metal 8.00
Alloy tubing @ 3.00 each for 4' lengths (Need approx 2lengths)
3mm nuts,washers and screws @ 20.00 for all
Then the rest which involved Clod parts:
Axles and such as described on the website.
I found the ESC to be the most expensive part involved
at 200.00 CAD.
**NOTE:
I just added these costs into the website, Thanks for
the heads up....I completely missed that part
Old 05-21-2005, 02:06 PM   #4
bendforthebone
cool little website. mines www.freewebs.com/customclods
badtodabone is offline   Reply With Quote
Old 05-21-2005, 02:07 PM   #5
Location: orange county n.y. , building the hydro crawler
That sheet steel is strong enough, especialy in the shock tower area?
sambmx is offline   Reply With Quote
Old 05-21-2005, 02:25 PM   #6
Good job! That's a great website. Nice and simple directions that anyone can understand.
AdamF is offline   Reply With Quote
Old 05-21-2005, 08:10 PM   #7
Just to clarify this....
It is not sheet metal, it is WELD steel I used
and it is Solid as they come. Goto your local
candian tire or such and search for it.
WELD 16G18 STEEL found in the same area
as the threarod and other metals.
Old 05-22-2005, 02:07 AM   #8
Update!
Not only did I insert the material costs for this project,
I also have the Clod hardware costs involved and
cleaned up a few things and added some more info
on the "Build-up".
If there is something you think would help, Please
reply here and I will try to clean it up further.
Im hoping this helps people out!
Old 05-23-2005, 02:40 PM   #9
hey man what part of canada you in?
wheeler is offline   Reply With Quote
Old 05-27-2005, 08:37 PM   #10
Im about just under 10 hours drive time from
you on the west side from Calgary.
Old 05-28-2005, 01:37 AM   #11
YGPM just to keep the thread on topic.
Old 05-28-2005, 08:13 AM   #12
A little rough, but thats pretty cool looking truck, for a clod that is.
Jeepjunky is offline   Reply With Quote
Old 05-28-2005, 09:56 AM   #13
By a little rough...... How do you mean?
Please be more specific!
Old 05-31-2005, 02:42 PM   #14
(highjack)I'm Canadian too
SiameseDog is offline   Reply With Quote
