01-09-2008, 08:42 PM | #1 |
Newbie Join Date: Nov 2006 Location: Newmarket ON. Canada
| Equal link lengths
I wanted to know if theres a problem running equal length links top and bottom, I was told that the top links need to be shorter, about 25% shorter then the bottom links.
01-09-2008, 08:46 PM | #2 |
RCC Addict Join Date: Nov 2005 Location: Kansas
I may not know what I'm talkin about (hopefully someone smarter will chime in) but I've always heard you want your upper and lower links close to the same size... but with the way most chassis are designed, I haven't seen it ran that way too often...
01-09-2008, 08:59 PM | #3 |
| Whoever told you that is a freaking tard. All thats gonna do is put your pinion in the dirt on droop. I feel equal length or a tad longer up top is better. That keeps the pinion angle and drive shafts angles allot happier throughout the suspension cycle.
01-09-2008, 09:07 PM | #4 |
I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
| x2 they don't know what they were talking about.
01-09-2008, 09:28 PM | #5 | |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
here something about same length uppers and lowers Quote:
01-09-2008, 09:57 PM | #6 |
Thanks alot guys. I just got the rock rider tube chassis for my ax-10. I got a set of the bent links and put them on the bottom then took the original bottom links and put them on the top, it seems to be working fine. Some one I know commented on the links being the same length, so I thought I'd ask the experts. Thanks again.
01-09-2008, 11:52 PM | #7 | |
Rock Crawler Join Date: Sep 2007 Location: Denmark
Quote: ......... Same length uppers/lowers will keep the pinion angle consistent throughout the suspension arch. Uppers a tad longer than lowers will push the pinion up a tad during compression on a sprung set up Same principles,just backwards results cause the suspension is working in reverse.][/QUOTE] you can use same length uppers / lowers depends on the amount of mounting locations on the chassis Last edited by SnoopMaxx; 01-10-2008 at 12:00 AM. | |
01-10-2008, 03:36 PM | #8 | |
Mounting locations on the chassis mean NOTHING to me as far as the length of the links go. In order to get a good,smooth,consistent suspension set up it's best to put the link where they NEED to go,not whatever works with the holes in the chassis. If the uppers need to be a certain length,and theres no hole there.....drill your own or make a link mount for that location. | |
