05-15-2008, 04:02 PM | #1 |
I joined the Band! Join Date: Aug 2007 Location: Paso Robles
| Max Degree of slope?
Could anyone tell me what they have found to be the max amount of slope on a comp course? Or an average amount of slope that makes a course challenging, but not over the top hard? Thanks |
05-15-2008, 04:12 PM | #2 |
Best way to find out is to get your rig and build a high traction slope (sandpaper on wood) and drive it Most natural obstacles are not straight inclines so the max angle changes when a rig can hook one of the front tires on something |
05-15-2008, 04:12 PM | #3 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
The length of the slope does a lot for crawlability. A short steep face is crawlable with wheel speed to shoot up the rock. A 4 foot face of the same angle may be impassable.
05-15-2008, 04:22 PM | #4 |
| Reason for question.
I'm working with 8' long x 4' wide panels. All will be made up with different rock formations on the faces. The panels will be adjustable, so I'm wondering what the max might be for a starting point, or finishing point, all depends on which way I can start working from. Thanks for your input guys. I appreciate it. |
05-15-2008, 04:56 PM | #5 |
| 45 degree to much?
With the base and back structure being equal, that would make it a 45 degree angle. Would that be to much for max slope, no matter what type of rock face is on it?
05-15-2008, 05:37 PM | #6 |
| Jax what the rambuller says is very true. You however don't have to necessarily have to stop at 45* angle you should be able to adjust beyond that and hopefully you'll be able to adjust it less than 45* as well. Your design needs to have adjustably.
05-15-2008, 05:44 PM | #7 | |
Thanks so much for your experienced input. | |
05-25-2008, 12:23 AM | #8 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
Almost sounds like you don't own a crawler. Mine will go up what seems like 70*-75*
05-25-2008, 12:26 AM | #9 |
most crawlers from what ive seen will max out at about 63-65* or so. thats very low slung comp specific rigs. i havent seen any go past 65 though.
05-25-2008, 09:41 AM | #10 |
