09-03-2009, 11:08 AM | #1 |
Quarry Creeper Join Date: Jul 2007 Location: Kentucky
| RC4WD 1\18 axle users: ujoints....here..
U-joints: https://sdp-si.com/eStore/Direct.asp?GroupID=545 Driveshafts: https://sdp-si.com/eStore/Direct.asp?GroupID=545 The .125" bore are the ones. There is a telescoping driveshaft that can easily be shortened as well as single and double jointed universals. I'll post up pics of mine once I get a minute. Be sure to get them "with insert" if you want a set screw. I am using a double jointed universal for the front axle and a telescoping shaft for the back. Another double jointed universal will be used to connect a micro gear motor to the Micro T transmission (acting as a transfer case). Only slight mods to the bore of the u-joints on the t-case ends and shortening of the shaft will be necessary for this to work. You're welcome. Last edited by GreenRiver; 09-03-2009 at 12:33 PM. |
09-03-2009, 11:44 AM | #2 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
I have gotten a few things from there for other projects. Quite the selection. |
09-03-2009, 11:57 AM | #3 | |
For those who are not aware of Global Spec, I suggest using it's search engine anytime you are looking for a weird mechanical part, gear motors and robotics stuff etc. http://www.globalspec.com/ | |
09-05-2009, 12:58 PM | #4 |
Rock Crawler Join Date: Jul 2008 Location: gilbert
Are you going to have a build thread for this rig? I am interested in doing something like this.
