02-04-2010, 10:32 AM | #1 |
Pebble Pounder Join Date: Sep 2008 Location: Dallas
| Delight lighting system
I found this link I dont remember how. But looks very compact which is great for a scale build. It has 8 channels which should be enough for all lighting needs for a RC truck.It is fully programmable which includes turn signals. And each channel can be programmed for the brightness. Here is the link http://www.dimensionengineering.com/...tarterKit.html has anyone ever used one of this.hoping to get some reviews. |
02-04-2010, 11:40 AM | #2 |
You can make the LEDS do anything you want with that....
06-09-2010, 02:42 PM | #3 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
I was about to order one of these yesterday. The PC based programing is great. I downloaded a copy and played around with it. You can program each output channel to blink, double blink, triple....etc, and fade or jump up in brightness based on the Rx input from the channel selected. Downside: single channel input (throttle or steering) Set points for when a light comes on or off is from 0 to 100%. So lets say you select the throttle as the input, you could have the front headlights turn off at neutral, turn on as you accelerate, then switch on the high beams at high throttle. What about reverse?? Brake lights or back up lights? I had one person tell me that on a wheeled radio versus stick, the trigger neutral position is actually 1/4 (25%) on the plus side already?? Thoughts and input?? |
