02-13-2010, 06:26 PM | #1 |
Rock Stacker Join Date: Mar 2008 Location: in my room
| rc4wd delrin springs
Crap.Nuff said.
02-13-2010, 06:34 PM | #2 |
Rock Crawler Join Date: Aug 2008 Location: Bristol Va.
huh..?
02-13-2010, 06:38 PM | #3 |
Either you can elaborate on your issue or I can delete it Please keep in mind the vendor bashing rule when doing so...
02-13-2010, 08:16 PM | #4 |
I wanna be Dave Join Date: Apr 2009 Location: Unnecessary Surgery Land
umad?
02-16-2010, 03:55 PM | #5 |
they are not strong enough to hold up to a stock hilux, apply any power and they bend into an S. I looked and asked about these springs before purchasing them so, this thread is more of a reveiw on the performance of the springs. I would not recomend them to anybody that will use their rig. But if you have the poser shot on the shelf, these might be your spring. Just in case someone else wants to look into buying them.
02-16-2010, 04:15 PM | #6 |
Most people who make delrin leafs typically suggest you run a track bar on the rear, did you try them with track bar?
02-16-2010, 06:25 PM | #7 |
a track bar locates the axle from left to right under the chassis. To fix this you would need to either run a traction bar, under the leaf would be best, or a 3rd link on top of the pumpkin. The problem isn't side to side movement of the axle. I just want to run a basic leaf spring set up without clearance eating traction bars that will also limit flex. I know flex is not that great with a leaf anyhow. I just wanted everything I guess, but who doesn't? I thank you for your suggestions though. Can't I just get four link flex with simple leafspring tech and still look scale. Waaaaaa |
02-16-2010, 06:45 PM | #8 |
Quarry Creeper Join Date: Sep 2005 Location: Canon City
For a set of traction bars that don't rob you of ground clearance and still allow you to flex decent here is an idea that I use on my 1.1 There is a bar on the top side of the springs that runs to the front hanger(you might have to blow the picture up to see it). I have wheeled this truck a ton and they help a ton. This could be adapted into the RC world fairly easy. Heres a better pic of these type of bar... |
02-16-2010, 09:44 PM | #9 |
You could easily make something like this http://www.budbuilt.com/new/traction_bars.html I have seen a few builds here where guys have made scale Bud Built trac bars |
02-18-2010, 10:05 AM | #10 |
Rock Crawler Join Date: Apr 2008 Location: Albany
"they are not strong enough to hold up to a stock hilux" that4byguy If the spring is to light a traction bar won't help. Every leaf sprung rig should have a link to the frame to stop axle wind up and wheel hop. Evan |
02-18-2010, 02:51 PM | #11 |
Quarry Creeper Join Date: May 2007 Location: Temecula, CA
That4byguy, if you want I can put the pic of the truck in action up so people can see how bad it really is?
