03-06-2010, 05:26 PM | #1 |
Quarry Creeper Join Date: Oct 2008 Location: Rochester Hills, MI
| rc4wd black widow axle?
Can i mount leafs to them and if i can how?
03-06-2010, 07:11 PM | #2 |
I have only seen one build with these so far and it was linked...I haven't seen anyone run leafs with them yet. I would imagine you could if you make the parts necessary to do it...I would also imagine you would need to modify the housing some.
03-07-2010, 07:23 AM | #3 |
I was thinking of using the leaf mounts from the rc4wd bruiser g2 axles but I need to know what the o.d of the axle tube is. Ill try contacting rc4wd. Thanks Kevin
03-07-2010, 09:08 AM | #4 |
Pebble Pounder Join Date: Mar 2009 Location: Gualala CA
I'm going to be running a front Black widow on my bruiser chassis,Leaf sprung. Should have the housing in a few days.I will post up info and how I will be mounting spring perch's |
03-07-2010, 09:16 AM | #5 |
I joined the Band! Join Date: Jan 2010 Location: Lanc.
Does this help you at all? |
03-09-2010, 05:40 PM | #6 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
03-09-2010, 08:06 PM | #7 |
03-14-2010, 05:10 PM | #8 |
OK got the Black widow Housing,Stripped down all the link Brackets and was able to use 2 brackets for candidate's for spring pad's ( 1 Extra )....After some measuring one spring is interfering with the Pumpkin ( like a Dana-60) It will have to be knotched. So I took my axle and frame down to the local machine shop,so They can get a good Centered Fit With a Sweet Pinion angle. I'll post pics of progress,Wont be for 3 weeks though |
03-14-2010, 06:47 PM | #9 |
Rock Crawler Join Date: Sep 2006 Location: Lititz
03-14-2010, 09:15 PM | #10 |
AHHH. Ok So here ya go Kevin,simple drawing of what I'm having done to the axle to accommodate bruiser chassis with leaf's. |
04-13-2010, 05:33 PM | #11 |
Got my axle back from machine shop....All I have to do is drill and tap two holes on axle for springs. |
