03-08-2010, 07:49 AM | #1 |
RCC Addict Join Date: Feb 2006 Location: Bellflower, CA
| NewBright TJ plastic question
Does anybody know what is the best type of glue to use on the NB TJ body. Im stretching it to make an LJ and i used Plastruct but it doesnt really adhere well to the NB plastic. The glue works great on the styrene but doesnt hold well to the plastic on the body. Also, is everyone elses TJ body really soft plastic like mine? Its so soft that i have been using a box cutter to cut and trim everything. Its not brittle like the JK bodies.
03-08-2010, 08:49 AM | #2 |
RCC Addict Join Date: Feb 2007 Location: sweden
I did my tubefenders with styrene rod glued to the NB tj body with plastruct, it worked for me, but maybe Tenax is better, i heard it should be a little stronger. One glue i just discoverd other then the styrene glue is Jamaras lexan glue, works really good if you want a strong bond. |
03-08-2010, 12:32 PM | #3 |
Quarry Creeper Join Date: Mar 2009 Location: Torrance, CA
Look for a glue that will bond polyethylene or polypropylene as that is what the TJ body is made from. eta: 3M corporation, 4693H is what you need. Last edited by Sydwaiz; 03-08-2010 at 12:51 PM. |
03-08-2010, 04:51 PM | #4 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
use tenax it's not really a "glue" it melts the plastic together creating a stonger bond than just gluing
03-08-2010, 08:34 PM | #5 |
I doubt Tenax will hold well but am eager to see if anyone has used it succesfully on polyethylene. Reason I say this is because Tenax is nothing but methylene chloride and polyethylene containers are used to store methylene chloride.
03-09-2010, 12:16 AM | #6 |
so sydwaiz what are you using, if anything, to bond these two plastics together? Any suggestions before i apply my first coat of paint? Thanks guys.
03-09-2010, 11:58 AM | #7 |
| Nothing as of now but I do injection mold it so I know how chemical resistant it can be. You can use Toluene as an ahesion promoter before you paint though. Wipe it on the surface, it should dry almost instantly, then paint. I have to use it when I pad print onto polypropylene parts. Paint still will not stick as well as it does to styrene though.
03-09-2010, 07:17 PM | #8 |
Ill try that stuff but where can i find it? Also can i use primer on the body before i paint it? Im hoping primer will stick to it so then the paint can stick to it.
03-10-2010, 08:57 AM | #9 |
