10-14-2010, 07:19 PM | #1 |
I wanna be Dave Join Date: Dec 2008 Location: ?
| servo winch question
Does anyone know how or if I can run my servo winch of a 3 position toggle switch? If so how is the power for this work. I was thinking just solder the servo wires to the three taps on the bottom of the switch then solder a red and black power wire back to my power plug? Is this right Thanks |
10-14-2010, 09:32 PM | #2 |
Pebble Pounder Join Date: Oct 2007 Location: gig harbor
yes you can, only if you are using the motor inside the servo and not the pot and circuit board. okay lets make sure you have the right switch. should have 6 tabs to solder to. 1 3 5 2 4 6 solder the batt power on 1 & 2 now take two wires and cross them from 1 to 6 and the other 2 to 5 that will change the polarity to make winch go in and out. haha, then solder solder two more wires from 3 & 4 to the winch motor. thats it, hope that helps later glenn Last edited by ggooler; 10-14-2010 at 09:40 PM. |
10-15-2010, 09:42 AM | #3 | |
Thanks man your getting me dizzy I really didn't think it would be that....... | |
