10-26-2010, 06:53 AM | #1 |
RCC Addict Join Date: May 2010 Location: The heart of the south
| Yeah Racing Shocks
Has anybody tried the Yeah Racing 90mm Threaded Aluminum Racing Shock Set on a Honcho? I am building a steel cage and using a Hilux body and I am for a little better performing shock than the stock. Or, any other recommendations? I also thought about the Axial Aluminum SCX10 shocks, ProLines Power Strokes (Damn they are pricey) or Traxxas Big Bores. The honcho climbs great with the mods, but I am adding a lot of weight. Goat 3S 18.5 Summitt 2 Speed 3S Lipos Hilux Hard Body Steel cage, sliders and bumper So, I want to make sure I can maintain the ride height and still provide the same level of shock function. |
10-26-2010, 04:33 PM | #2 |
RCC Addict Join Date: Mar 2009 Location: hawaii
couldnt you just use stiffer springs? no sense in buying new shocks, if its gonna be heavier youll just need a higher spring rate id imagine, the scx10 shocks are good and if your talkin about the anodized ones i think theredirt, i bought a set and couldnt even get the rubber in the shock cap to seat properly, there a cheap crappy shock |
10-26-2010, 07:49 PM | #3 |
RCC Addict Join Date: Oct 2008 Location: PA
I've had 8 of them (6 90mm and 2 80mm) and love them. You can buy a set of 4 for the price of a pair of PowerStrokes. As for the comment above, not sure why you had issues. They come with 3 spring rates. My truck weighs about 6lbs (estimate) and I use the soft ones. The soft springs, 50wt, and 2 hole pistons is the magic setup for me And they don't leak a drop. They flex just as much as the Axial's, if not a smidge more. The PowerStrokes only flex like a Axial shock WITH the rubber spacer. You can check out my Bronco build in my sig if you want pictures. The ones I have - http://www.tcscrawlers.com/Yeah-Raci...I-p-16975.html Last edited by Gimp; 10-26-2010 at 07:56 PM. |
10-26-2010, 08:17 PM | #4 |
Ive used them on a lot of my scalers and love them, price is perfect and they are very smooth. I used a set on my Big Tex FJ with Associated buggy springs as a dual rate setup And current all 4 on my Yota George with RC18T springs |
