Go Back   RCCrawler Forums > Scale Rigs General Tech > General Scale Talk
Thread: styrene ?
Old 11-24-2010, 07:13 PM   #1
Default styrene ?
I am wanting to start my frist body build and have some questions about
bending styrene to make corners. Is there any advice you guys can give me about bending it to make 90* bends?
Thanks Ben
Ben06 is offline   Reply With Quote
Old 11-24-2010, 07:40 PM   #2
Thanks Ben
Do you have a heat gun?
You will have to use some type of heat to get a tight bend like that without breaking it.
bassinguy is offline   Reply With Quote
Old 11-24-2010, 07:42 PM   #3
0 0
romulus22's Avatar
Also the glue/solvent can be used. The solvent will soften the styrene till it dries.
romulus22 is offline   Reply With Quote
Old 11-24-2010, 07:44 PM   #4
Sounds like a good idea, I am gonna have to try that
Old 11-24-2010, 07:50 PM   #5
0 0
romulus22's Avatar
Ive tried heat and I personally haven't had good results. Heat tends to shrink and warp if you don't do it right, Which I obviously don't.
Old 11-24-2010, 07:57 PM   #6
vacuum box works the best
Old 11-24-2010, 08:01 PM   #7
That is a nother thing that i am unclear on. what glue is the best to use?
will some super glue work or is there a glue that works better?
I do not have a heat gun. I wondered about heating a piece of steel that is the shape i want and bending it around that. Keep the info coming guys
I need all the help i can get in this.
Old 11-24-2010, 08:05 PM   #8
0 0
romulus22's Avatar
This is the stuff I use and works great for me
http://www3.towerhobbies.com/cgi-bin...?&I=LXDJ94&P=W
Old 11-24-2010, 08:23 PM   #9
I used this also because it actually welds the styrene together.
