05-18-2011, 10:25 PM | #1 |
I wanna be Dave Join Date: Nov 2008 Location: Chillin in Utardia
| Need longer rear center drive shaft??
So I have a set of MIP ax10 drive shafts. I stretched the rear and I need about another inch to make this work. I already have the links made up and the mock-up looked perfect. Just need a longer drive shaft. I looked on MIPs site and they dont have measurements. ANy help will be appreciated.
05-18-2011, 10:44 PM | #2 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
try tower they have spec's on most products, type MIP in the search and read what mip might work.........bob .... |
05-18-2011, 10:55 PM | #3 |
Tried them first actually. The only one that MIP makes that could be longer then mine doesnt even have specs.
05-19-2011, 06:07 AM | #4 |
RCC Addict Join Date: Apr 2009 Location: United States of the Offended
05-19-2011, 06:51 AM | #5 |
Rock Crawler Join Date: Jun 2010 Location: KCRC
05-19-2011, 08:30 AM | #6 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
Purchase a spare male MIP shaft half. Pull your cv appart from you current female shaft half. Cut the end off the female shaft. Slip the female shaft over the disassembled male shaft to a location that gives you the length you need. Through bolt it, pin it, or best is to have a local metal shop heliarc weld it in place for $5. |
05-19-2011, 01:29 PM | #7 | |
| Quote: | |
