10-04-2011, 12:45 PM | #1 |
| micro (kill) switch on winch to prevent drifting?
im a cheap ass. had this idea to do a micro toggle switch and mount it next to the winch (would look sorta scale winch lever) and basically kill the power to it until i need it. you have to touch the winch anyway to grab the hook/line. but would this work? and which wire would be best? positive? signal? negative? :hmm: |
10-04-2011, 01:16 PM | #2 |
Chassis & Tubework Vendor Join Date: May 2006 Location: Portland, OR
I've setup a few servo winches with a on/off switch. Wire it up to the pos and neg lines.
10-04-2011, 01:18 PM | #3 |
im not looking to control the winch with the switch. just kill power to it. so when not in use it doesnt drift.
10-04-2011, 01:43 PM | #4 |
Rock Crawler Join Date: Oct 2006 Location: Fernley
I have done this when using the stock 3racing controller. Either the pos of neg should work fine. I just ran mine off the positive wire.
10-04-2011, 01:48 PM | #5 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
Run the pos. and neg. wires through the switch, leave the signal wire. This is how Chino63 told me to do mine, works great. I have a 3 position switch for front and rear winches. |
10-04-2011, 01:55 PM | #6 |
10-04-2011, 01:55 PM | #7 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
i do this in all my scalers, simply to avoid drift or accidental spool in. here is a little schematic i drew up. i usually cut the power wire. hope that helps. |
10-04-2011, 01:57 PM | #8 |
That's awesome^ |
10-04-2011, 01:58 PM | #9 |
10-04-2011, 03:34 PM | #10 | |
Thats exactly what I saying. Just to kill the power when not in use. Wire a 2position switch inline with the pos and neg. Keep the signal wire always connected. | |
10-04-2011, 04:10 PM | #11 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Trenton, with a 2 pos switch you break either the pos or neg.Not both and you defenitly dont put one on each side of the switch. Like Cory said, that would be a dead short if one was on each side. Just make sure it is accesable in most posistions the truck may end up in.Sucks to get a repo penality if you cant get to the switch to turn the wnich on. |
