10-11-2011, 08:14 AM | #1 |
| Bell Crank Steering?
anyone fooled with this? bell crank mounted to the axle. servo mounted to the chassis(in front of skid). thoughts? ideas? examples? waste of time? |
10-11-2011, 08:59 AM | #2 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
Theo old Kyosho Twin Force had a similar setup, work ok for the truck, but not really scale or precise for crawling. Sounds like a lot of unneaded stuff to try and cram on a axle? I have use a modded frame mounted steering bellcrank off a Tamiya Hilift. Mimic a real steering box better than a servo hanging off the front of the frame.
10-11-2011, 09:15 AM | #3 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i thought bout doing that with my clod build, but room was an issue where i wanted to mount the servo....but i was thinking of making an extention with some alum plate off the top of knuckle to move it forward and backwards with a rod from servo mounted back in the chassis....i think it would work good ........bob .... |
10-11-2011, 09:35 AM | #4 |
RCC Addict Join Date: Oct 2007 Location: gervais
Wasn't the stock wheely king sorta set up like this? Other than the placement of the servo?
10-11-2011, 07:47 PM | #5 |
Oliver Custom Knives Join Date: Dec 2007 Location: Bloomfield NM , not something stupid
This is what I did on my Wreckluse From the side From the front Worked real good |
10-11-2011, 08:36 PM | #6 |
How about the og hilux/bruiser system |
10-12-2011, 09:50 AM | #7 |
Rock Crawler Join Date: Apr 2008 Location: Albany
01-14-2012, 04:35 PM | #8 |
Rock Crawler Join Date: Jan 2006 Location: coventry, ct
| Re: Bell Crank Steering?
I did the same type steering on my wreckluse (mean green) over a year ago, the rig has been to acouple different owners sence and its still working flawless! No bumpsteer and lots of steering due to offset cantilever arm. I mounted servo under the driver seat.
05-21-2012, 11:29 AM | #9 |
RCC Addict Join Date: May 2010 Location: Midwest
I want to do an axle mounted bell crank on one of my builds. Anyone have any more info/pics?
05-22-2012, 04:47 PM | #10 |
ahhh S^*T Join Date: Mar 2012 Location: in the shop bending metal in Whatcom Co. WA.
this is a thread I wanted to start myself, I also want to try this.. looks really scale if you do it right too!! I think its a good method to the madness of CMS |
08-29-2012, 07:43 PM | #11 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
Anyone tackled this? Kind of peaking my curiosity. |
08-30-2012, 12:41 PM | #12 |
Rock Crawler Join Date: Oct 2011 Location: Vertical Junkie
I guess its ok if you need the room under the hood. I do like the weight closer to the center of the skid also..
05-26-2015, 09:27 PM | #13 |
Newbie Join Date: Aug 2013 Location: Quebec
I ran into this old thread while looking for ideas and I think some interesting ideas had been posted there, so here is my setup. The servo is mounted right in front of the transmission, between the upper links. It was a pain to figure out and took a good amount of time to build, but I'm satisfied of it It does suffer from minor bump steer. projet-custom-rock-bouncer |
05-26-2015, 09:29 PM | #14 |
mmmmmm, 4 link and CMS. That looks great. |
05-26-2015, 10:22 PM | #15 |
3 links and a panhard would get rid of the bump steer, but I didn't want one |
04-07-2020, 09:31 PM | #16 |
Quarry Creeper Join Date: Jul 2011 Location: ireland
bump
