Go Back   RCCrawler Forums > Scale Rigs General Tech > General Scale Talk
Thread: shock upgrade
Old 12-04-2011, 09:01 PM   #1
Default shock upgrade
hi guys im from australia and i just bought my first crawler its a axial scx10 honcho and i was just wondering what are some good mods i can do to it.
i was after some more hight and flex what are some good shocks to achive this.
what are some other good mods to do to this rig to make it crawl better.
thanks.
yazholes is offline   Reply With Quote
Old 12-05-2011, 12:03 AM   #2
A lot of 4 link guys run Power Stroke shocks on their scx10s at the comps I attend. They all seem to be very happy with them.
Snowmaninhell is offline   Reply With Quote
Old 12-05-2011, 05:27 AM   #3
Adding height and flex will probably make it worse 99% of the time. Too much height it falls over, too much flex it ties itself in knots.
Biggest things you can do to a SCX10 to make it crawl better are 4 link rear, weight the wheels and try and get your battery as low as possible. Have a look around at the SCX sub forum and do a few searches. There is plenty of info out there on what works and what doesn't.
I'll 2nd the proline power stroke scaler shocks for a excellent upgrade. They have a longer shock body with same length shaft though, so you actually loose about 2-3mm of flex. Another good upgrade is the Axial aluminium bodied SCX10 shocks. They are the same as stock, just with aluminium bodies for some extra strength and smoothness.
As i said, have a good look around at what others have done. You'll get plenty of ideas and inspiration.
WIDELOAD is offline   Reply With Quote
