Go Back   RCCrawler Forums > Scale Rigs General Tech > General Scale Talk
Thread: Ugh!
Old 06-10-2006, 11:40 AM   #1
Default Ugh!
My driveshaft keeps popping off , its the plastic on that goes onto the transmission. tryed drilling a hole in the stub thing but its like hardened steel and it took me 10 min and i barely started the whole..any ideas?
CoreyK is offline   Reply With Quote
Old 06-10-2006, 12:15 PM   #2
Get some steel yoks and some locktite. That should solve the problem.
Rockcrusher is offline   Reply With Quote
Old 06-10-2006, 12:24 PM   #3
yea. got a question. is there a safer way to put ball joints in the yoke then bending the yoke back with pliers? i broke them .
Old 06-10-2006, 01:18 PM   #4
what i did is got one side set in place and then pushed it downwards on the floor, it pops almost atw and then just use pliers to get it in the last little bit.
pliers are only good for the last little part of getting them in.
murdock is offline   Reply With Quote
Old 06-10-2006, 02:20 PM   #5
Wild trial's Avatar
I always put mine in some boiling water,, then they get soft
and fine before I put them on.....
Wild trial is offline   Reply With Quote
Old 06-10-2006, 03:18 PM   #6
to get them to stay on get the updated output shafts and diff gears, It's like 9 bucks. you are talking about the pede tranny right?
skidooguymxz550 is offline   Reply With Quote
Old 06-10-2006, 05:14 PM   #7
You need a new drill bit. Tamiya's steel is pretty soft. I can drill through one in 45 seconds, and I use a 9.6V Makita with a 1989 battery.
microgoat is offline   Reply With Quote
