01-06-2014, 10:22 AM | #1 |
Rock Crawler Join Date: Jan 2012 Location: Mcallen, Tx
| Beef in Yer Rear! to Tube? or NOT to Tube?
so ive been debating on this subject a while and i want some other opinions on it, how many of you guys run beef tubes in the rear on your scx/wraith based rigs, and why? i decided to beef front and rear because i liked the idea of my chubs and lockouts bolting into the tubes and forming a "one-piece" solid axle so to speak, and of course weight down low, but now im thinking do i need it? is it hurting me? is it helping me? on the trail? on the rocks? speak up guys! Last edited by Big Tex; 01-06-2014 at 11:05 AM. |
01-06-2014, 10:31 AM | #2 |
| Re: Beef in Yer Rear, to Tube? or NOT to Tube?
I think the weight down low is the biggest advantage for the rear axle... but ya never know, it cold save ya in a roll over. |
01-06-2014, 10:34 AM | #3 |
Cracked a rear axle in the past. So yep, beef tubes in the rear axle for me.
01-06-2014, 10:38 AM | #4 |
i think for me it helps me stick when i side hill and also when im making a steep climb, but it could be more the OD/UD and C.I. foams but it makes me feel better that its helping lol |
01-06-2014, 11:13 AM | #5 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
I think it's one of the things that depends on the rest of the rigs weight placement. I like a heavier axle set but in the wrong rig a rear axle that's too heavy is going to make it want to back flip on steep climbs. How hard would it be to pull them out on a day run to try the rig without it. |
01-06-2014, 11:16 AM | #6 |
| Re: Beef in Yer Rear! to Tube? or NOT to Tube?
well prying off the lockouts is no fun task, and all my weight is up front basically, and saddle pack lipos on my r2j g6 sliders so its biased well IMO
01-06-2014, 11:57 AM | #7 |
I roll BT's front and rear... I also purchased alloy C-hubs, knuckles and lockouts and wanted those secured better then with screws threaded into plastic threads. I think the BT's (Ft/Rr) are a must do improvement if yer serious about keeping the rubber side down... and making the axle's stronger. 'bout the only drawback... the plastic axle housing gets chewed to hell in the rocks. and that requires replacing the housing from time to time. Not difficult by any means... but one will need break out the dremel, each/every time a new axle housing is installed. I regret not using new axle housings during the original install of the BT's 'cuz I already need to change those out My opinion is... just do it ! |
01-06-2014, 12:01 PM | #8 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
I watched two guys, on the same day, split open wraith axle housings (one at the shock mount on the long side tube, and one at the pumpkin) on a jump at a scaler event. Both rear housings. I did the same jump, same exact set up, only difference, I had beef tubes front and rear.. My truck lived. That right there was enough for me to say yes, front and rear is a good thing.. |
01-06-2014, 12:05 PM | #9 |
Quarry Creeper Join Date: Sep 2011 Location: Lexington
Front and rear, strength and weight. But if you don't install a bec also then the beef tubes are pointless...
01-06-2014, 12:18 PM | #10 |
Quarry Creeper Join Date: Mar 2006 Location: Pewee Valley, Kentucky
What brand's seem to work best?
01-06-2014, 12:44 PM | #11 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
steel toobs upfront delrin in the rear.. |
01-06-2014, 12:58 PM | #12 | |||
| Re: Beef in Yer Rear! to Tube? or NOT to Tube? Quote:
good points guys, anyone see a difference with dirt hilling, mud or snow? or are we all just WOT everything? lol cuz i do Uh-Ohh Wild card! A1 steak sauce has a nice set of tubes available, all jokes aside, biggin69 is the beeftube king IMO best pricing, good clean machining, fast shipping great communication etc cant beat em | |||
01-06-2014, 01:03 PM | #13 |
Thanks! Who makes the delrin rears?
01-06-2014, 01:08 PM | #14 |
| Re: Beef in Yer Rear! to Tube? or NOT to Tube? heres the link, and delrin tubes?! im a man! i have no such knowledge! http://www.rccrawler.com/forum/axles...e-updated.html |
01-06-2014, 04:09 PM | #15 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: Beef in Yer Rear! to Tube? or NOT to Tube? |
01-06-2014, 04:14 PM | #16 |
Creationfab splined tubes for the xr mod are also nice. Regular beef tubes work but the axle plastic eventually gets gnawed up, for me it did anyway.
01-06-2014, 05:40 PM | #17 |
top 10 best thread title |
01-06-2014, 05:42 PM | #18 |
I prefer the added weight of the steel beef tubes. I also prefer that the C-hub securing screws thread into steel rather then plastic. Tho' Delrin is stronger then most plastics... I still prefer the tapped steel threads... Should last longer if removed and reassembled repeatedly. I have the biggin69 "standard beef tubes" Other designs may create a wider axle. And I personally did not want that. Only issue was... if using the stock axle shafts... those can have interference with the ID of the inner ends of the beef tubes (locker side). That interference will not allow the axle shaft the ability to seat properly and can cause bind with the axle shaft. I used the stock axle shafts in the rear. I had to chamfer the ID of the inner end of the BT's. Reason being... the stock axle shaft has a inner shoulder that is a bit large in diameter. Suppose you could grind the axle shaft's shoulder down.. but it could weaken the axle shaft some. It's really simple to do. The BT's are the correct over-all length... so that shouldn't be altered. It's just the ID at the inner end of the BT's. It only needs be chamfered a little to clear. Just don't chamfer the angle so much that it shortens the over-all length of the BT. I used Axial universal shafts up front... and those fit fine without chamfering the ID of the inner end of the BT's. reason being... a much smaller shoulder on the axle shafts inner side. But if using the stock axle shafts up front... they will need chamfering. I chamfered all four tubes... so that they will work in either axle housing... regardless of which axle shaft is being used. ^ and so I can't confuse which BT goes into which axle housing if I might break down both axles at the same time. |
01-06-2014, 10:16 PM | #19 |
01-07-2014, 04:42 PM | #20 |
I wanna be Dave Join Date: Jul 2008 Location: Southwestern, Ohio
Just stumbled upon this thread. Thank you to all of my satisfied Beef Tube Customers! |
Beef in Yer Rear! to Tube? or NOT to Tube? - Similar Threads | ||||
Beef tube ? | jcsaxial | General Crawlers | 3 | 08-28-2012 02:15 PM |
What the heck is a Beef Tube? | Arctic Fire | Newbie General | 14 | 01-18-2012 01:38 PM |
