07-28-2014, 11:49 AM | #1 |
RCC Addict Join Date: Nov 2008 Location: Central, WA
| scx10 ifs
I've had a plan for an ifs/irs rig on the back burner for awhile. Wanting to collect parts from a few twin hammers I'm not having any luck. Sure I could buy 2 used rollers but what a waste of the rest of the rigs. I started looking at other options cause the twin hammers steering is not that impressive. Touring cars have really short a arms and short axle shafts limiting the flex by putting the CV at its limits before trying to steer. I ran across a losi mini 8ight and from what I see in the pictures it looks like a good starting platform. Shaft driven, 2.2 wheel, 12mm hex, long travel, and fairly cheap ($160 for a new slider). I spent a few hours searching for builds and found nothing, searched for specs on the mini 8ight and found nothing. Question is does anybody have one that can take a few measurements for me? Width hex to hex Will a 1.9 fit Pics of the steering lock to lock What size drivelines to the pinion gear Are they pretty durable? |
07-28-2014, 03:37 PM | #2 |
Rock Crawler Join Date: Feb 2012 Location: Tennessee
| Re: scx10 ifs
I actually picked up a ifs project from Eric113 awhile back. After I completed the build I took it out for a few trail runs and I am super impressed with everything except what you have mentioned.. the steering is terrible. The positioning of the servo above the steering rack causes binding no matter the direction of mounting, steering link length, or servo arm length. I tried several combos. Funny thing is I was considering using a bell crank set up and the mini 8ight is very close to the correct measurements. They do use a 12mm hex, and the bell crank arm measures right at 50mm almost exact to the twin hammers slide mounting points. It is right at 7 1/4 from hex to hex, almost dead on with the scx measurement hex to hex. Here is turn to lock I can see using the bell crank on the twin hammers set up, but the weak point will be the size of the driveline parts on the mini 8ight. The axles are tiny 2.56 mm thickness. |
07-29-2014, 01:53 PM | #3 |
| Re: scx10 ifs
Thank you for the reply! A guy on Facebook stripped his car apart for me last night and sent me a bunch of pictures and tried several different wheel/hex options too. Looks like I'm going losi for sure! I'll add the pics and info to this thread when I get to a computer! Looks like the only real obstacle is going to be using the rear setup. The pinion gear is somehow attached to the spur gear. I may have to run another front housing if I can't figure out how to mount a front pinion in the rear. The shafts should be OK with class 1 tires, if not I'll find a way to stuff something else in there! |
07-29-2014, 01:54 PM | #4 |
| Re: scx10 ifs
Anyone know if the buggy and truggy are the same width? Also someone said the vaterra rally car is the same rig??
07-29-2014, 04:01 PM | #5 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: scx10 ifs |
07-29-2014, 06:12 PM | #6 |
Newbie Join Date: Apr 2008 Location: australia
| Re: scx10 ifs
What about the traxxas 1/16 rigs . I have used the longer arm 1/16 summit on two ifs /axial Toyota builds . |
07-31-2014, 05:27 PM | #7 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
| Re: scx10 ifs |
07-31-2014, 05:30 PM | #8 |
| Re: scx10 ifs
I read that one! I almost started collecting parts but I really want steering!
07-31-2014, 11:02 PM | #9 |
Rock Crawler Join Date: Jan 2011 Location: Blaine, MN
| Re: scx10 ifs
why not look for a touring car that there are many drift upgrades too? The very small bit of drifting I did I saw some pretty crazy angles on some cars. Just a though.
08-05-2014, 04:20 PM | #10 |
Pebble Pounder Join Date: Sep 2010 Location: Far from you
| Re: scx10 ifs
Check this build out, it might help ideas check out scale builders guild, search for wall rock rig, the guy who makes it pretty much makes the whole IFS
08-05-2014, 06:52 PM | #11 | |
| Re: scx10 ifs WALL Rock Rig - Axial IFS Rock Buggy Quote:
Sweet! I can't see the pics on the original build cause I'm not a member, but it looks cool! I might have to attempt my own if the losi doesn't work out. I'm gonna check one out at this weekends comp and go from there! I guess I could use any center section and use a knuckle and shaft set up like that! | |
08-05-2014, 06:56 PM | #12 |
| Re: scx10 ifs
Free registration on that sight to man,worth it to check that build out it's amazing
08-05-2014, 07:00 PM | #13 |
| Re: scx10 ifs
I know I just try to limit myself on how many forums I check daily! Looks addicting lol
08-05-2014, 08:23 PM | #14 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: scx10 ifs
If you're a motor/gear head like most of us...they are all addicting I'm following this as it has always interested me as well....keep it up Toy |
08-06-2014, 07:57 AM | #15 | |
| Re: scx10 ifs Quote:
08-06-2014, 08:02 AM | #16 |
| Re: scx10 ifs
You better keep a close eye on it! I'm bringing tools!
08-12-2014, 08:22 AM | #17 |
| Re: scx10 ifs
Well I got my hands on the losi/vaterra rig this weekend (thanks hotwheels) and wasn't real impressed with the strength or the steering. Also the width was a little narrow for my barbie Volvo wagon. So I think I'm gonna go with the home brew route. I was hoping to do a good simple build thread that anyone could follow with simple hand tools but oh well. Now I get to do a one off build with my machines! Not sure on the center section but I'm looking at the exo if I can ditch the dog bone cups and replace em with a no slop locker and a through shaft to accept slash universals. And a knuckle setup like riff_raff pointed out in that awesome wall rock buggy. Probably use wraith knuckles to get the 8* king pin angle or just machine my own so I can keep the axle really low in the knuckle like a twin hammers knuckle. Thanx for all the input helping me form a decision, stay tuned for a build thread soon (after I finish a few customer builds)!
08-12-2014, 10:36 PM | #18 |
| Re: scx10 ifs
Got to a good stopping point on the customers rig (raining and gotta pull my bike out to weld) so I threw together ax xr10 knuckle, shaft, and made an adjustable width temporary A frame. Should have my traxxas shafts tomorrow (need telescoping universals). Looks like I'm gonna have killer steering which is one of my major concerns. This will be a comp rig, not just a play toy. Need to order a set of exo diff housings tonight to keep from stripping my exo lol! Anyway here's a few pics! |
08-19-2014, 11:08 AM | #19 |
| Re: scx10 ifs
any updates on your progress on this?
08-19-2014, 01:07 PM | #20 |
| Re: scx10 ifs
I wish. I've got a customers TJ build on the work bench right now that takes priority, and I'm helping the local hobby shop by doing all of his customer repair work that eating up my spare time. Also working on putting my new scx10 chassis into full production.
scx10 ifs - Similar Threads | ||||
IFS SCX10... Good or bad? | mitchr97 | General Scale Talk | 8 | 04-13-2013 03:53 PM |
Ifs scx10 | Maverick52 | Axial SCX-10 | 1 | 03-05-2013 11:14 PM |
Ifs scx10 | markturbo | Scale Videos! | 8 | 04-19-2012 02:24 AM |
IFS SCX10 Project | markturbo | Axial SCX-10 | 14 | 04-15-2012 07:23 AM |
