01-31-2020, 06:48 PM | #1 |
Newbie Join Date: Dec 2019 Location: USA
| Gluing tires - What brand is best?
What is everyone's tire glue preferences? I picked up some crap "thin" tire glue from Hobbytown today and almost destroyed my wheels/tires. It reacted weirdly and turned brown on contact. I'm trying to mount some Proline Destroyer tires on some Proline Brawler wheels. Sent from my SM-N976V using Tapatalk |
01-31-2020, 09:20 PM | #2 |
Quarry Creeper Join Date: Dec 2019 Location: Woodstock
| Re: Gluing tires - What brand is best?
i have used super glue with good results. Work a small section about 3/4 - 1 inch at a time, going around the the ring. pep |
01-31-2020, 10:00 PM | #3 |
AKA has worked great for me. https://www.amainhobbies.com/aka-pre...ka38001/p28069 Bob Smith Industries as well. They also make "Insta-Set" and "Un-Cure" products that work great. Insta-Set is a life saver for mounting tires and or building custom tires. If you notice at some stores like HobbyTown, they just sticker slap their sticker over BSI bottle labels. https://www.amainhobbies.com/search?...ith%20glue&p=2 |
02-01-2020, 07:30 AM | #4 |
| Re: Gluing tires - What brand is best? That's not a glue problem, that is the mold release agent on the tires fouling the glue. You need to clean the tire beads to get all that stuff off or it is going to ruin your glue job regardless of the brand.
02-01-2020, 01:05 PM | #5 | |
| Re: Gluing tires - What brand is best? Quote:
X2, I like Team Losi thin for tires, but use beadlocks for crawling. | |
02-01-2020, 01:41 PM | #6 |
Rock Crawler Join Date: Oct 2009 Location: Upstate NY
For modifying tires I like to use the BSI IC-2000 For standard tire gluing, I've always had good results from BSI and Proline thin glues |
02-01-2020, 04:59 PM | #7 |
Rock Stacker Join Date: May 2019 Location: Upstate, NY
I second the BSI IC-2000. Further, ALL BSI glues are superior to the typical store-bought CA's. I always thought CA's were the same regardless of packaging. The BSI stuff is SUPERB P.S. I have no affiliation w/ BSI. Learned how good it is after using it. Now I use no other brand. |
02-01-2020, 05:38 PM | #8 |
I won't say it's the best, but it's the best I've used: BSI Ultra Cure. I have a way of gluing myself to tires if I go any thinner than that, and the thick stuff doesn't seem to have as strong of a bond (or it's just my imagination?) BSI is also local to me, but I'd been buying his products for years before I realized that. Of course, the dollar store mini tubes of super glue are handy in a pinch, but using the Ultra Cure has proven considerably easier and more consistent for me. |
02-01-2020, 07:49 PM | #9 |
Newbie Join Date: Dec 2017 Location: Bensalem, PA
I have been using E3000 industrial adhesive on tires for years. It holds very well and the best part is that you can just peel the tire from the rim if you ever need to separate them. Unlike super glue where you'll need to bake them or use solvent to get them apart. The E3000 will be perfect for your 2.6 wheels/tires. I race Clods and have used this method on all of my race trucks and never had an issue. Bonus, you can reuse tires and rims later as the adhesive will just peel right off with no mess. |
02-03-2020, 07:02 AM | #10 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
I just use the medium CA that the hobby shop sells. I forget the brand. I'm not sure if it's the "best" or not, but I haven't had a single tire separate from a wheel yet.
02-03-2020, 07:48 AM | #11 |
Thanks to all! I'm so nervous about screwing up my new tires and wheels that I can't get myself to sit down and get it done. That ends this evening. Here it goes... Sent from my SM-N976V using Tapatalk |
Gluing tires - What brand is best? - Similar Threads | ||||
R/c tires 101 – tips on gluing | CKRC Hobbies | CKRC Hobbies | 2 | 01-24-2021 03:56 AM |
priming tires for gluing | slowlearner | Tires and Wheels | 9 | 02-14-2011 02:19 PM |
gluing tires | johnnyt | Tires and Wheels | 13 | 10-03-2006 09:55 AM |
