Go Back   RCCrawler Forums > Scale Rigs General Tech > General Scale Talk
Thread: Drive Lines Remove
Old 03-04-2021, 07:00 PM   #1
Default Drive Lines Remove
Okay, got a question. Bought a used rig, and can't get drive lines out. Seems like pins were put in with some kind of lock tight. They won't move. The hex driver is ready to strip. Any ideas?
Rocky Bar is offline   Reply With Quote
Old 03-04-2021, 07:30 PM   #2
Default Re: Drive Lines Remove
Try heating them up with a heat gun. If you have a micro torch and they're metal parts, you can get away with pinpoint heat where if you're careful, you won't mess up the plastic parts.
OnTheTrail is offline   Reply With Quote
Old 03-04-2021, 07:48 PM   #3
Ahhh, thanks for the speedy reply. Will try heat. Also thought of cutting them out. And replacing them. Last resort I guess. Cheers.
Old 03-04-2021, 08:10 PM   #4
I use a small tip on a soldering iron to heat it. If you have one, it's great for getting heat only where it's needed.
Sent from my SM-G970U using Tapatalk
Steve g is offline   Reply With Quote
Old 03-05-2021, 02:49 PM   #5
Okay, got them out with heat. Used a small heat gun that I use on shrink tube.
Took a lot of heat with hard twisting of hex driver. Big thanks for all the advice.
Cheers.
Old 03-05-2021, 02:53 PM   #6
Cheers.
Drive Lines Remove - Similar Threads
The Best Drive lines? Coolinthewoods General Crawlers 1 02-08-2014 09:52 PM
How are Rc drive lines measured? Docwolf General Crawlers 3 09-16-2012 05:03 PM
Drive lines... Nova Axial Wraith 13 08-19-2012 07:29 PM
