Go Back   RCCrawler Forums > Scale Rigs General Tech > General Scale Talk
Thread: tamiya TLT axles
Old 04-01-2021, 04:17 PM   #1
Default tamiya TLT axles
I have a custom scaler i built a long time ago using tilt axles. i am wanting to put the drive shaft from a scx10 II on it. i have them built to exact size. but my problem is the pinion shaft that comes out of the axle to connect the drive shaft too only has a flat spot on them. I need a hole through them to install my scx10 II drive shafts. are there any other pinion bevel gear and shaft that will work in the tilt axle . i was going to try to drill through them but the part that sticks out is just a little short so the scx10 driveshaft won't go back enough for the pin to go through it. if any of that made sense. thanks
Harleyrocker is offline   Reply With Quote
Old 04-01-2021, 04:41 PM   #2
Default Re: tamiya TLT axles
You could just use a set screw on the driveshaft instead of a screw pin. The Ascender did that which is less than ideal as it likes to come loose so a liberal application of loctite is a must.
Would it help to grind down the end of the SCX10.2 driveshaft or am i getting that backwards?
HumboldtEF is offline   Reply With Quote
Old 04-01-2021, 05:12 PM   #3
the axle will go over the pinion shaft fine, but I can't use just a set screw because the pin helps hold the drive shaft ends together. i started to drill but it won't be in the right place, not enough room on tilt shaft to drill where i need
Old 04-09-2021, 08:42 PM   #4
Drilling TLT pinions is a scary, not so recommended procedure (lotsa broken pinion shafts)
Back in the day we used a set screw on the flat spot... they constantly popped off
Some company many moons ago (RCP?) made aftermarket pinions out of hardened steel that had a hole already bored, though I'm sure they've been discontinued by now
grob23 is offline   Reply With Quote
Old 04-09-2021, 09:58 PM   #5
I have always just drilled through the shaft. It's not hard if you have a drill press, but can be done with a vice and cordless. Always centerpunch!!
Gula is offline   Reply With Quote
Old 04-13-2021, 06:43 PM   #6
what other axles, that have the hole in the pinion shaft, mount up like the tilt axles so i can use all my links and mounting hardware
tamiya TLT axles - Similar Threads
Tlt axles brand new from tamiya james399 Tamiya TLT Crawlers 7 02-16-2018 07:51 AM
