04-16-2007, 12:47 PM | #1 |
Pebble Pounder Join Date: Apr 2007 Location: Deer Park
| High Lift springs from RC4WD http://rc4wdstore.com/product_info.p...roducts_id=514 Rc4Wd offeres these ^ for the high lift.... How do I attach these on my high lift axels without having U bolts? Am I completely retarded? |
04-16-2007, 12:58 PM | #2 |
Quarry Creeper Join Date: Jan 2006 Location: colchester
my guess is that you would have to match up where the holes would be and drill them
04-16-2007, 01:03 PM | #3 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
you wont be able to unless you drill holes on either side of the center pin, atleast with stock mounts.
04-16-2007, 02:14 PM | #4 |
Their email response says they bolt right up!!!! someone wanna hook these guys up with better information. These things are a P.I.T.A to drill cause the flashing behind it makes the leaves seperate!!!!
04-16-2007, 02:25 PM | #5 |
yeah, if i were you i'd return em and get diaz leafs. thats bunk that they say for F350, and bolt right up. return em and shoot diaz a pm.
04-16-2007, 02:26 PM | #6 |
did you ask if there are 2 different sets? maybe they have some for bruiser apps and some for high lift? and yea thats Bs if they say they fit then they should fit.
04-17-2007, 12:31 PM | #7 |
Quarry Creeper Join Date: Aug 2005 Location: On the yellow dummy dumper
I see nothing about them fitting a hi-lift. I do see that they fit a Jugg which came with an F350 body on it |
04-17-2007, 12:54 PM | #8 |
this is what the site says as a desription " [SIZE=Ř"]4x Heavy Duty Lift Kit for Tamiya Bruiser, Mountaineer and Juggernaut[/SIZE] [SIZE=Ř"]On bruiser, you will give you more clearance for bigger wheels. On F-350, these leaf springs are 25% softer, allows more flex![/SIZE]
as far as i can see they are saying that they are a direct bolt on for the F350 |
04-17-2007, 12:57 PM | #9 |
yes, which to me says its a direct replacement for tamiya's RC Ford F350 High-Lift, but good luck directly fitting those on a RC Ford F350 High-Lift http://www.tamiyausa.com/product/ite...oduct-id=58372 |
04-17-2007, 12:58 PM | #10 |
^^^thats exactly what im sayin |
04-17-2007, 01:57 PM | #11 |
x2 Thats why I emailed them and tried to call them (voicemail box with a direct line) with a little clarification. Those boys need to use spell check also, Im not perfect but Im also not running a business |
