04-16-2007, 05:52 PM | #1 |
Rock Stacker Join Date: Jun 2005 Location: Houston
| Bump Steer!
Hello everyone, I just recently built a custom crawler with the steering servo attached directly to the chassis. I'm having problems with excessive amounts of bump steer. Can anyone tell me how to remedy this without having to attach the servo to the axle? Thanks, -Aaron- |
04-16-2007, 06:14 PM | #2 |
Quarry Creeper Join Date: Aug 2004 Location: Southwestern PA
It would help if we knew what type of suspension setup you're running and how the servo is connected to the axle...
04-16-2007, 06:39 PM | #3 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
observe, think, adjust.
04-16-2007, 06:53 PM | #4 |
Here are some pics. |
04-16-2007, 07:14 PM | #5 |
Quarry Creeper Join Date: Nov 2005 Location: Australia
i think the main problem is that the servo is attached to the chassis instead of the axle. maybe just try it on the axle and see if that solves the problem. if it doesnt, look somewhere else. |
04-16-2007, 07:35 PM | #6 |
one problem. servo saver. second problem theres a long screw being used on the pass knuckle for the two link ends. either shorten that screw or get aluminum knuckles. that will clear up alot.
04-18-2007, 07:48 PM | #7 |
Take a look at this one. He apparently has zero bumpsteer with his setup. As far as I can tell, his draglink is longer and it uses a Z-bend. Military Geländewagen Build Also, rather than the z-bend thing, you might wanna try a spacer between the draglink and tierod to get the draglink more parallel to the tierod, that might do the trick. The downside is that you lose some steering leverage and put extra stress on the knuckle arm. |
04-18-2007, 09:22 PM | #8 | |
I wanna be Dave Join Date: Mar 2005 Location: Hiding from Goodall
Steep, can you post a side shot of your rig? It looks like the links are kind of steep going out to the axle thus causing them to pull the axle in much faster when it drops from ride height. This looks like more of an issue than the steering to me | |
04-19-2007, 02:53 AM | #9 |
| That certainly clears things up and means I'm on the right track at least. I kept looking at Ryan's build and when Ryan said "with the Z-bend I get no bumpsteer" I was trying to figure out how. But now it makes sense; his servo is over much further than Steep's so the draglink is longer which is what really reduces the bumpsteer along with keeping the draglink and tierod parrallel. Right?
04-19-2007, 08:01 PM | #10 |
I have been tinkering around with this chassis and i'm not very satisfied. I definately need to decrease the break-over angle of the suspension links. I also need to make both the upper and lower suspension links the same length or damn close to it. I feel that the COG for this rig is fine, even with the motor mounted high up. Like Slugz mentioned, all of my problems, (besides the bumpsteer, which I know how to fix now ) are related to my suspension geometry. I will definately be in the garage this weekend. Here is a side shot of my rig in it's current set-up. Its all about to change. Thanks for your help fellas, Aaron |
