04-18-2007, 10:01 AM | #1 |
Rock Crawler Join Date: Oct 2006 Location: England, Where the birds fly backwards.
| how hard could it be?
Would this be in any way possible in anyway. i'm not saying i would do it but just wondering. (not the half track though) http://www.lr-mad.co.uk/tracked.html |
04-18-2007, 10:23 AM | #2 |
Quarry Creeper Join Date: Jan 2006 Location: colchester
its possible it seems like it may be kinda difficult but doable. you would need to find tracks that are the right size, probably off of a small scale dozer or something. then all it is is finding a way to mount them and figuring out how to get small wheels with small teeth type pieces coming off them. then you would be all set
04-18-2007, 10:23 AM | #3 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
honestly - i think that this would be pretty easy... txt-1 front axle tamaya tank txt-1 tranny and custom frame landrover body and extra lexan... tada... |
04-18-2007, 11:02 AM | #4 |
I think matching the front and rear gear ratio would be your only problem. Either way, I don't think it would do so well on the rocks. I just have never really liked the tracked vehicles that much anyway though. Except.......did anyone here have the Fast trax (sp?) I had the red one I think. Man that thing was fun! |
04-18-2007, 07:01 PM | #5 |
Quarry Creeper Join Date: Jun 2005 Location: quarryville
the ones with tracks for each wheel... maybe you could use parts from trannys ? on tlt axles mounted solid to the axle soo the gears spinn but the bracket on the axle says put ? or you could use somthjing other then tlt axles for a full scale look
04-18-2007, 07:55 PM | #6 |
Rock Stacker Join Date: Apr 2007 Location: england
it would probably take quite abit of custom machining for the basic structure that hold the shape of the tracks, but the driveline parts can be taken straight from a cheap 'hobby grade' RC tank, such as a Hen Long the wheel with the teeth is called the sprocket or drive wheel, and the other wheels that just roll the track are called road wheels |
