05-11-2007, 01:21 AM | #1 |
Rock Crawler Join Date: Apr 2007 Location: Nor*Cal
| Shaving TLT Axles
Anything I need to know, beware of, not do, etc. before shaving some TLT axles?
05-11-2007, 09:39 AM | #2 |
I wanna be Dave Join Date: Jan 2004
I flipped mine axles so they are "reverse rotation". Then ground all the crap off. Gives you a tad more clearance and leaves the top all shiny and pretty.
05-11-2007, 11:55 AM | #3 |
When you are done you can use a fine grit sand paper and then hit it will some jewelers rouge. I just use the polishing pads with the dremel and you can get about 70% of the shine back. May even help you a bit on the rocks.
05-12-2007, 01:07 AM | #4 |
Good ideas, thanks!
