08-06-2007, 04:04 PM | #1 |
Rock Crawler Join Date: Aug 2006 Location: nc
| ta02 on 2.2
i just put mk2's on wk wheels on my ta02 and i need a little more space in between the frame and wheels so it doesnt rub when turning. does anyone know of a way to space it out more?
08-09-2007, 07:43 AM | #2 |
Quarry Creeper Join Date: Oct 2005 Location: Chattanooga
I would just get a wheel with more offset. I did the same thing with my Hummer, the larger tires give the ta02's some much needed ground clearance. You could also make a custom chassis, that way you could also increase your breakover clearance. Lex |
08-10-2007, 12:31 PM | #3 |
Quarry Creeper Join Date: Mar 2007 Location: plymouth
wheel wideners
08-10-2007, 01:48 PM | #4 |
RCC Addict Join Date: Feb 2007 Location: MS Coast
I just got a ta02 and like the ide of 2.2s. Could you post some pics. The one I have has a custom extended frame(cutting board I think) that is only a couple of inches wide so the 2.2 ires would probably work.
08-10-2007, 01:56 PM | #5 |
Quarry Creeper Join Date: Aug 2005 Location: On the yellow dummy dumper
The 2.2s, especially M2K's, are pretty hard on it and provide low amounts of torque. They are good for the snow though...
08-10-2007, 03:07 PM | #6 |
This is mine that I talked about earlier. I have a lot of work left to be done but I think I have most of the stuff to finish it.
08-10-2007, 03:10 PM | #7 |
ΜΟΛΩΝ ΛΑΒΕ Join Date: Dec 2006 Location: In tha Bush of Louisiana
get-r-done sound like your alot like me so many project so lil cash
08-10-2007, 11:46 PM | #8 |
Rock Crawler Join Date: Jan 2006 Location: Dallas
get some axial beadlocks...there fairly cheap and have alot of off set.Or get some wideners?
08-11-2007, 11:47 AM | #9 |
Rock Crawler Join Date: Apr 2006 Location: Pineville Ky
| TA 02 on 2.2s
This is what i have been working on, i havent figured out how to lower the gearing yet . Anyone have any suggestions Last edited by NU2KRAWLIN; 10-24-2007 at 08:15 PM. |
08-11-2007, 02:41 PM | #10 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
There was a mod somewhere on how to get a 12t pinion to work. Not sure how well your dogbones will hold up to the bigger tires and a 12t pinion.
08-12-2007, 08:39 PM | #11 |
I have tried to find the 12tooth pinion mod with no luck. If i figure out a way to do this i will post up some pics |
