10-10-2007, 01:12 PM | #1 |
Rock Crawler Join Date: Apr 2007 Location: Nor*Cal
| CVD and 1.9 RC4WD Beadlock Problem
Just got some 1.9 wheels in from RC4WD and noticed that the center hole on the wheel is too small for the cvd. Should I just drill out the hole on the wheels? Or do I need to switch over to non-cvd's?
10-10-2007, 01:31 PM | #2 |
Web Wheeling Join Date: Jan 2005 Location: Twin Cities
Drill the hole out.
10-10-2007, 01:32 PM | #3 |
Rock Crawler Join Date: Feb 2007 Location: CoMo...Kickin it with Holmes Hobbies
the cvd's dont fit through any wheel..you have to drill the wheel out to make them fit...
10-10-2007, 01:53 PM | #4 |
10-10-2007, 02:01 PM | #5 |
Donkey Punch Champion! Join Date: Oct 2006 Location: Minneapolis
They have had a couple different size holes for the axles to pass through. Certain sets where different. The answer is most definately to make the smaller diameter larger to accomidate the CVD's. Please post some pics to show others this? Good luck. Ryan |
10-10-2007, 02:12 PM | #6 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
Are you going to put the center cap on? With the size of the CVD screw, you may have to alter the center cap's backside. I had to, just to get them to fit over a locknut.
10-10-2007, 02:25 PM | #7 |
Rock Crawler Join Date: Jul 2004 Location: OC, Oregon
You will need to cut off the end of the cvd aswell. Otherwise you cant run the center cap.
10-10-2007, 06:50 PM | #8 |
Yeah, I still want to use the center caps. Thanks for the info. I'll probably get to work on them tomorrow.
10-15-2007, 07:31 PM | #9 |
Well, how did it go? Let's see the wheels mounted already. Ryan |
10-15-2007, 09:16 PM | #10 |
10-15-2007, 09:41 PM | #11 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
I usually just use my body reamer to enlarge the hole.
