05-29-2008, 12:34 AM | #41 |
RCC Addict Join Date: Jul 2006 Location: So Cal USA
06-01-2008, 10:01 AM | #42 |
Newbie Join Date: Nov 2004
| monster backorder
Hey John, I had another question on that Monster backorder issue if you can please email me. (think my email may have got spam-tossed) Also, wish I had the cash for that Z00!.. thing looks fun, good luck with the sale. |
06-01-2008, 10:42 AM | #43 |
Winner of the '07 RCC dumbass award! Join Date: Nov 2006 Location: Up on a Mountain, out in the Woods
| Waterproof???
Sometimes, its just not wheelin without H2O... Anyone know anything as far as the Monster being waterproof? I realize the fan might not like it but have they coated the boards in epoxy like the MM and the M 25? Sorry, just hard to have a motor capable of 2.5 HP and not point it at the mud. WC |
06-10-2008, 08:34 PM | #44 |
Quarry Creeper Join Date: Oct 2004 Location: Hopkinsville
Hey John, any news on the status of these bad boys?
06-10-2008, 09:31 PM | #45 |
WC- it is conformal coated but I wouldn't get it wet. For a sand rail, you can select as big of a motor as you want. The wind will be determined by voltage, and size will determine your overall power. A 2,000 kv motor on 6s would be a blast and have really long runtimes. The latest news- Castle is trying to determine the cause of a 30% BEC IC failure rate. The part is sourced from a factory that can't help them, so it is bouncing between bad part or design flaw. My ESC is still running strong. I would expect them to figure it out and do another run within 6-8 weeks, but that is totally a guess. |
06-23-2008, 09:27 AM | #46 |
Quarry Creeper Join Date: Feb 2008 Location: Rhode Island
Hey John, it says you have 8 or 9 in stock.. Does that mean if I order one its going to ship, or is that a pre order or back order? I am going to be buying the parts to turn my LST2 into electric. Still deciding on motors but im thinking a 9XL on a 4S 10,000MAH MaxAmps lipo. And of course the MMM... Let me know! |
06-23-2008, 10:52 AM | #47 | |
Rock Stacker Join Date: Sep 2007 Location: Longmont
Leigh | |
06-23-2008, 11:08 AM | #48 |
The MMM had one hardware issue that is being resolved. One part was not holding up to quality control standards (A chip that Castle buys to control the BEC), so they are redesigning and figuring out the best way to resolve the issue. I have taken down the 9 preorder and updated the product information to reflect the change. Once I get a lead on when they will be remanufactured I will give some updates. Mine is still running strong, but some of the units had an early failure because of the bad components which Castle could not control. |
06-23-2008, 11:21 AM | #49 |
So when do you think you will have them in stock? This isnt something I will be getting this week, more like in a few weeks or so. If the MMM isnt in stock at the time, how is the Castle Hydra 120?
06-23-2008, 12:02 PM | #50 |
The hydra doesn't have brakes. I would suggest waiting if the MMM isn't done when you are ready to buy. A few weeks of patience will make sure you don't waste money and you get something made for a monster truck. I am hoping 4 to 6 weeks on the redesign. |
06-23-2008, 12:27 PM | #51 | |
1.) Because I run a CC BEC there will not be a problem right? 2.) Does the problem only effect the BEC? 3.) Will castle be taking back version 1 and replacing it with the newer one? Thank You! WC | |
06-23-2008, 12:29 PM | #52 |
You can still have the problem with an external BEC, if the internal BEC on the MMM fails it won't work. The problem only effects the IC of the BEC- something Castle could not control Castle will repair any MMM that has a problem. If it is not repairable then it will get replaced. |
06-23-2008, 12:36 PM | #53 | |
Sweet! I have run about 6, 4S A123 packs through mine.... Took the gear reduction off last night to see how it would do. Have you run a 3032 on anything large and fast?!! It throws my 18-20lb rig around like it weighs 4 ounces! I can not get over the power! My Monster got rained on at the finals last weekend too, never missed a beat. WC | |
06-23-2008, 01:08 PM | #54 |
Brakes dont matter to me as I wont be using them through the motor anyways. Going to run a Y Harness like everyone else with the LST2 and run the actual brakes it would use with the nitro through the servo. Most people are using the Hydra 120, but if you want crazy power there is the Hydra 240. Also, then there is the MGM speed controls. I have a lot of looking around to do but I dont know if I am going to wait or not on the MMM. If its got bugs I think ill wait a few months and then get it once they are all sorted out. I dont want to wait for it, get it and then have it screw up on me you know. I would rahter get something that works, let them figurer it all out and then get it becuase I LOVE the programability the castles have. Thanks for the help! |
06-23-2008, 01:23 PM | #55 |
The big difference between the Hydra is the startup routine. The hardware is different and it isn't as solid on startup as the mamba line of controllers.
06-23-2008, 07:23 PM | #56 |
Alright, so do you know of a good speed control that can do what I need? Other than the MMM. Do you have any of the MMM's you would sell me? I need something within the month, and it needs to be able to handle at least 120Amps as the LST weighs like 15lbs loaded with electric parts.. |
07-06-2008, 03:00 PM | #57 |
Quarry Creeper Join Date: Nov 2004 Location: Mid TN
JRH, Would the BEC problem that's going on with the MMM show a degraded performance, or would BEC just quit working? I'm curous because my servo's don't seem to be getting enough juice to turn my rig right.
07-06-2008, 04:54 PM | #58 | |
Quarry Creeper Join Date: Jan 2006 Location: Orlando
Also, the internal BEC in the MMM is not 6V, so if you're used to your servos running on 6V before the MMM, that could be the issue. | |
07-06-2008, 07:47 PM | #59 |
Thanks, that's probably it. Might be time to see if there's a meaner servo for less than 6v.
07-06-2008, 08:44 PM | #60 |
| Why not just add a Castle BEC? If you use a short servo extension with the red wire removed, you have isolated the MMM internal BEC to running itself only. Then, just add the Castle BEC set to your preferred voltage and you're set. I mention adding the extension so you still have the full complement of wires for programming with the Castle Link when you unplug the MMM from the servo extension cable. In this setup, the MMM BEC only powers it's brain board and the Castle BEC runs your Rx and servos. It'll be cheaper than replacing servos.
