Go Back   RCCrawler Forums > Vendors > Holmes Hobbies
Thread: Hyperion chargers
Old 01-02-2008, 07:01 PM   #1
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Default Hyperion chargers
Holmes Hobbies carries the full line of Hyperion Chargers and Balancers. They are hands down the easiest to use on the market, with great track records for reliability and construction quality.
Hyperion 0606i
The big brother to the 5i, with AC input and integrated balancing. Easy 4 button design. If you are using a lot of lipo packs this charger/balancer is for you.
Hyperion 0610i
This is the big daddy of the series. DC only input, 250W charging capable, with integrated balancing. If you want to charge at high amperages this is your charger. Uses memory functions to charge, so it isn't quite as quick to set up a new pack as the 5i and 0606i.
JohnRobHolmes is offline   Reply With Quote
Old 01-02-2008, 07:10 PM   #2
Adilynsdad too!
braceysdad's Avatar
I had an ICE a Triton2 and now a 6i...
I got rid of the ICE and use the Triton2 as backup yeah, the 6i is that good.
The built in balancer makes charging lipos a breeze...
By far the easiest and best charger I have ever owned!
I might just pick up another to replace the Triton2
braceysdad is offline   Reply With Quote
Old 01-02-2008, 07:18 PM   #3
I use the 5i on the road and the 06i at home. Lipos don't need balancing EVERY charge, and the 5i is stinkin tiny.
Old 01-02-2008, 07:22 PM   #4
Adilynsdad too!
braceysdad's Avatar
Good point, and thanks for the idea...
Old 01-02-2008, 07:28 PM   #5
I felt so self indulgent when I got my second charger for the road. Heck, I own a dang hobby store and still only have 3 mamba max's. Two were from the first batch out of Castle too
It is nice to leave the heavy charger at home though. The 5i isn't much thicker than the pack of cards.
Old 01-02-2008, 07:30 PM   #6
Adilynsdad too!
braceysdad's Avatar
hahahaha...
I own a hobby store too, I just don't ever sell anything
Old 01-02-2008, 07:45 PM   #7
Originally Posted by braceysdad View Post
hahahaha...
That's funny.....
You're filling up my sig line...
4u2nv is offline   Reply With Quote
Old 01-02-2008, 08:11 PM   #8
John,
You are killing me...I have Comp Electronics GFX, Pitbull and a Venom Balancer. I was eyeing the 10i and 5i up for the same reason you stated.
I see you only have one 10i...will you be getting more? Need to see what I can dump this weekend at the Winter Monster Bash...
Rckcrwlr is offline   Reply With Quote
Old 01-02-2008, 08:17 PM   #9
Thanks for catching that I only have one 10i in stock, I will go ahead and order a few more tomorrow morning.
Old 01-06-2008, 11:02 AM   #10
Here's a link to the user manuals. Definitely worth looking into when I head up to lipos. Will you be eventually be doing a full review at some point?
http://media.hyperion.hk/dn/eos/
Teapot is offline   Reply With Quote
Old 01-06-2008, 11:07 AM   #11
I can certainly do a review. Any certain model you want to see?
Old 01-06-2008, 11:15 AM   #12
I'd say either the 5i or the 06i, but pretty much any of them would be good.
Old 01-06-2008, 04:42 PM   #13
JRH,
I will do a review on the 10i...send me a test one out... ;)
John
Old 01-10-2008, 08:56 AM   #14
I've been eyeing the 6i cause I'm in the market for a charger. My 5yr old intellipeak wasn't worth a flip 5 yrs ago and I'm wanting to go lipo soon. I'd like to see a review on the 6i.
Thundermaxx is offline   Reply With Quote
Old 01-20-2008, 12:37 PM   #15
Finally got to digging into my package from Holmes Hobbies.
John,
These chargers are the best. Easy setup and use. All the power and options I will ever need.
The 10i is so easy to use. I had a GFX that took more time to set than it did to charge. This thing gets up up and running within 10 mins and that is just setting up your profiles.
The 5i is a fully capable "portable" charger. No frills just get the cells charged. Not to say that the 10i is not portable. I was shocked when it arrived. My GFX was huge.
Thanks for offering another great product.
John
Old 01-20-2008, 01:03 PM   #16
john recommended the 06i
It is the best charger i have owned.
lime is offline   Reply With Quote
Old 01-20-2008, 01:12 PM   #17
No doubt...I was going with the 6 and then changed to the 10 with the 5 in my pitbox...
Old 01-20-2008, 01:12 PM   #18
TEAM MODERATOR
Reflection's Avatar
You won't regret buying the Hyperion 0606i. This thing is a work of art. Hands down,one of the best chargers I've used. I thought my old chargers were working great....WRONG. I've noticed quicker charges and a touch longer run times on my current cells.....Yes,they are all old wore out cells.
The only new batteries I have is a 3 cell 2100 and this Hyperion 0606i works that like a champ.
Reflection is offline   Reply With Quote
Old 01-20-2008, 01:17 PM   #19
Same here...I was using a Comp Electronics Turbo 35 GFX...one of the best chargers out there...I paid over $400 for it. It did everything you wanted and more...but you had to program it...
The Hyperion is performing as good or better with less programming. The 6i, from what I understand, is even less programming for more than half the cost of a GFX.
It is a no brainer.
Old 01-20-2008, 01:22 PM   #20
TEAM MODERATOR
Reflection's Avatar
My 11 year old son figured it out in minutes.
He said,after he figured it out....."That old charger is junk Dad."
You may edit your posts
