01-23-2008, 09:32 AM | #1 |
Rock Crawler Join Date: Jan 2008 Location: Essex, UK
| Steering linkage kits
I've just got my WK and have had a quick blast. Wicked machine I have a locked diffs, rc4wd stretch kit and longer shafts coming, but one thing I have noticed that really needs sorting out is the steering... its rubbish! Theres very little lock and it struggles to turn the wheels when sitting still. I think this is mainly to do with how much play there is in all the steering components. Would a longer servo horn without a saver on it help lock and reuce the slack of the saver being there? And does anyone make a complete kit to remount the servo on the front? (i.e with rods, ends, and mounting plate) While I'm asking lol... does anyone make a more rigid rear steer lock out? (other than the straight hub option, might want 4 wheel steer one day) I dont like how much the rears move about. Many thanks peeps! Simon |
01-23-2008, 09:46 AM | #2 |
Pebble Pounder Join Date: Jun 2007 Location: somewhere
I wouldn't even bother with the stock steering set-up. I tried that and even replaced the servo. With all the plastic in the steering, you'll always have play somewhere. You can always make your own mount, its pretty easy. I used a scrap piece of aluminum, 4-40 all thread, rod ends and stainless steel tubing. Check out my set-up: My wk build so far... You can also buy complete kits, do a search in the vendors forum. |
01-23-2008, 09:54 AM | #3 |
Thanks mate, Haha I saved the pics of your steering setup not 2 seconds before you posted that lol Like the setup on the rear, looks really good Thats a mean rig. Could you give me a pointer for which vendors to try?... Not many UK shops do these kind of parts and I dont know many of the vendors "across the pond" lol |
01-23-2008, 10:16 AM | #4 |
This is one of the steering kits you can get from a vendor: http://www.rccrawler.com/forum/showt...=steering+kits Looks like a good solid mount. |
01-23-2008, 12:46 PM | #5 |
Rock Crawler Join Date: Oct 2007 Location: richmond, va
ckrc has a complete kit with mounting plate a rods
01-23-2008, 04:44 PM | #6 |
I see that requires the suspension mounts to be rotated, is there one that doesnt require this? Wanna keep them as they are ideally...
01-23-2008, 04:49 PM | #7 |
Quarry Creeper Join Date: Jan 2008 Location: akrowdy
the ckrc kit is nice ... rotating the mounts isn't a bad thing just mount the shock on the top and the lower link on the bottom on the inside
01-23-2008, 05:12 PM | #8 |
I'm just picky thats all lol, I like the suspension acting from the top of the axle.
01-23-2008, 11:20 PM | #9 |
Quarry Creeper Join Date: Jan 2008 Location: Eagle Mountain, Utah
I didnt want to rotate my mounts when I did my steering either. if you are at all mechanically inclined and have a dremel tool you can do the steering yourself for under $20. You just need this template http://jowettskustom.forumotion.com/...emplate-t8.htm Some 22 gauge steel or thin aluminum ($5.00) and some 6-32 threaded rod ($1.00) aluminum tubing ($2-$5.00), 4-40 screws/nuts ($1.00) and some rod ends ($4.00)... Last edited by dacaur; 01-27-2008 at 02:21 AM. |
01-24-2008, 04:19 AM | #10 |
Pebble Pounder Join Date: Jan 2008 Location: Lanexa,Va
nice you should post this in the wk free servo mounts
01-24-2008, 04:37 AM | #11 |
dacur: Does the servo faul the chassis when the suspension is compressed? The link doesnt work for me :( |
01-24-2008, 08:09 AM | #12 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
01-24-2008, 08:11 AM | #13 |
Rock Stacker Join Date: Oct 2007 Location: Devon, UK
This is the set-up for rear lock-outs i used. Works great and gets rid of all the long links. It does mean rotating the mounts, but they get hung up stock anyway. |
01-24-2008, 08:41 AM | #14 |
Wow loads of great info here, thanks fella's!
01-24-2008, 09:38 AM | #15 |
That's a great idea for lockouts. I wish I would have thought of that or seen it before I shaved my tabs off. Maybe I'll try to acquire some more for that set-up.
01-24-2008, 07:08 PM | #16 |
Quarry Creeper Join Date: Jan 2008 Location: Edmonton, AB
does JK's mount work with TCS upper link mounts like what motormad has.
01-24-2008, 08:08 PM | #17 |
Rock Crawler Join Date: Dec 2007 Location: USA
heres one that looks rly nice http://www.teamstrc.com/ebproductdet...ainid=8&id=101 |
01-25-2008, 03:39 AM | #18 |
resetpunk: Yeah I looked at that too, but I think the main thing that causes slop in the steering is the mount for the crank on the axle. It bends and moves when put under load, i think one of these would tightedn things up no end : http://rc4wdstore.com/product_info.p...roducts_id=628 |
01-25-2008, 03:54 AM | #19 |
01-25-2008, 11:44 AM | #20 |
ya thats very high up. what chassis do you have motormad?
