| | #1 |
| Newbie Join Date: Aug 2007 Location: huntsville
| Hey everyone I know some of you guys are like me and want to put bigger tires on your WK. Well I was able to put a set of Losi Claw MT Tires mounted on a set of magneto chrome rims on my WK I think the tires are 40 series or 420 series, alot bigger than stock. It actualy was no that difficult, I got all the stuff needed from Lowes and it only cost about $10.00 bucks (minus the rims and tires of course). Let me tell you a little bit about my WK, WB is about 15 to 16 inches, not sure on width have not measured it with new tires and wheeladapters yet, and it weighs about 6.5 lbs. I have a Integy 65 turn motor, 15/96 gearing and silly putty in the diffs, I know the putty does not always hold but I like the fact that it will give before I break something. As far as the tires go I love them |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Jun 2007 Location: somewhere
| How about some pics? |
| | #3 |
| Rock Crawler ![]() Join Date: Aug 2007 Location: oak harbor
| It is very interesting that you posted this thing. I just got my WK last night with no electronics. I will be extending my wheelbase to 16". Running 4ws and a 27t motor 55 for comps. My idea was to run the standard size maxx tires hopefully cutting down on some drivetrain stress. But the 40 series would even be better. |
| | #4 |
| Rock Crawler Join Date: Dec 2007 Location: USA
| doesnt it put more stress on motor and tranny? |
| | #5 |
| RCC Addict Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
| | #6 |
| Something like that. I just opened up my wk no electronics version and started hacking away i will have 8inches longer wheelbase and am looking for bigger wheels/tires. And yes this is gonna be extra stress on the system. We will see what axle breaks first |
| | #7 |
| Hey it's RockRider again been away for a little bit sorry to leave anyone hanging on the pics but I should be able to get some up tonight |
| | #8 |
| Pebble Pounder Join Date: Sep 2007 Location: Kalamazoo
| yep I run T-maxx rims and tires on my sons WK. there not much larger than the stock tires so it handles it fine. |
| | #9 |
| Rock Crawler Join Date: Dec 2006 Location: Sierra Vista
| Funny to see this bumped....I've been in the process of making some taller moabs, got 2 of them mounted tonight, will get the other 2 done before the comp next weekend(need more beadlock screws). They came out to 5 3/4" tall mounted, with the weight of the tuber on them they should be about 5 1/2" tall, definately more clearance for the wide WK axles then regular 2.2 moabs. The main reason I wanted to try this is get more clearance because of the width of the WK axles, and I think it'll work. Also working on clearancing the link/shock mounts on my axles, I've done the front need to do the rear now, once the rear is done there is nothing to get hung up on under my tuber. I can't wait to see how things turn out, I'm hoping it isn't going to affect my COG too much but I've got a droop setup and it doesn't sit very high as it is, and I can always adjust the shock mounts to makke it sit a little lower. |
| | #10 |
| Rock Stacker Join Date: May 2007 Location: Lousyana
| The Wk axles and tranny will hold up fine with bigger tires on it. I was running some Maximizer X-75 bead locks with some modded Maxx size rock claws and loved it but I am trying to get it ready for comp specs. And the truck is only 12.5. The xtra ground clearance is nice but you will have to sacrifice COG and probably want to lower your chassis to compensate. This was the beginning of my WK build. |
| | #11 |
| Power of the Portals ![]() Join Date: Feb 2004 Location: where ever the wind fawkin blows me, tx
| | #12 |
| anyone have any feed back on running dual motors |
| | #13 |
| Well I am going to run dual motors, I need just a little bit more power to run big tires |
| | #14 |
| Pebble Pounder Join Date: Nov 2005 Location: Raleigh
| on my first WK I run maxx sized mashers with no trouble. On my other, I originally ran jumbo maxx swamp dawgs with the stock trans and 32p gearing, then bought some LSTs super cheap and the gearings just wasn't low enough. So... I used the stock trans as a t-case and put a stampede trans up front. Now it has a lot of versatility for gearing and can be set up for low speed or high speed stuff. |
| | #15 | |
did u have any problems with flexing and the tires hitting the shocks or chassis? | |
| | #16 |
| Rock Crawler Join Date: Jan 2008 Location: Jonesboro, Arkansas
| | #17 | |
i'm running a K2 L and a K2 S on both of them, and neither have any issues with rubbing the shocks/chassis.... just make sure you have enough offset on your wheels and you'll be fine | |
| | #18 |
| | #19 |
| Hey everyone I love the rigs, I could not find the right wheel to fit my WK without the tires rubbing, so i made the spacers from the parts i got at lowes, you can see a video of my WK on youtube here is the link http://www.youtube.com/watch?v=mnDlrD5UmyY let me kow what you think, also this vid is pre dual motors, which is one of the best things I did to my WK so much more power when needed. |
| | #20 |
| Newbie Join Date: Apr 2008 Location: The Far Side
| So how do you go about fitting larger tyres? All the 40 series and maxx rims have larger hexes. Do i just fit a larger hub adapter? I've got the proline moab 2.2's on at the moment, and would like to try the moab XL's but don't know what rims to fit them to. The proline bead-loks say they are 23mm hubs? How do you make that fit a 12mm hub adapter! |
| Thread Tools | |
| Display Modes | |
