| | #1 |
| Quarry Creeper Join Date: Jun 2007 Location: Del mar
| This thing is sweet! You would think with the stock tranny it would have a really high CG. It isn't as bad as you would think. All of my weight is way down low right where it should be. Thanks Don(Billet Works) for making such a great kit for the Wheely King. And sorry for scratching it up before I took pictures. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| Sponsored Links | |
| | #2 |
| Billet Freak ![]() Join Date: Jun 2007 Location: Earth
| That thing turned out great! I didn't realize you were running such a beastly motor on that thing! Scratches just mean it's getting some great use! Don VF |
| | #3 |
| I had to Dremel out the motor slots to fit M4 mounting screws in it. I like power and I am thinking of getting a bigger motor when someone makes steel tranny gears with no slipper clutch. Awsome work Don. |
| | #4 |
| Newbie Join Date: Sep 2005 Location: San Diego
| Looks like you could use some skid plates |
| | #5 |
| Rock Crawler Join Date: Aug 2007 Location: mesa az
| i'm not a big fan of that chassis for some reason it looks really heavy and alot of sharp corners to get hung up on but those wheels are the s#!t i must get my hands on a set |
| | #6 |
| Pebble Pounder Join Date: Jun 2007 Location: somewhere
| That's A LOT of battery!!! I'm not sure about the chassis though. It's nice, and well built, but it seems like the motor/tranny placement could be improved. |
| | #7 |
| Newbie Join Date: Jun 2007 Location: San Jose
| how well do those lower links slide on rocks, it seems they'd just slide over since there's no bend and they are out of the way for the most part. Also, would it be possible to get a couple shots of the front axle? Thanks, Nasher |
| | #8 |
| Pebble Pounder Join Date: Nov 2007 Location: Canada
| Looks good, but the chassis/links isn't much of an improvement geometry and ground clearance wise... :-/ |
| | #9 | ||||
No sharp corners here, everything is rounded slightly. Get your fix of the beadlocks here. Quote:
There is no need to "improve" the chassis, everything is well thought out and functions very well together. Quote:
![]() ![]() ![]() ![]() Quote:
The T-Maxx shocks lower it alot, because they are shorter shocks than the Wheely King's shocks. | ||||
| Thread Tools | |
| Display Modes | |
