| | #1 |
| Quarry Creeper Join Date: Sep 2007 Location: mountains of ca
| Well I am pretty new to building a crawler. I have had several clod crawlers but I bought them all except for one I did build from ground up 3 yrs ago. So this is gonna be fun. There is so much info here its amazing. I shouldnt have a problem building one.Enough talk on with the pics right locked axles with jb weld Imex 2.2 swamp dawgs rpm revolver crawler rimes cnc'd wheel extensions integy 55t motor 96t spur gear 15t pinion either a novack fusion esc or novack explorer 2 working on making my own servo mount but think i may end up buying one. Just cant get it right. rest of truck is stock for now. trying to find a good chassis and links... here some pics ![]() ![]() ![]() let me know what you think, am open for suggestions |
| Sponsored Links | |
| | #2 |
| Rock Stacker Join Date: Aug 2004 Location: holland oh
| i think im going to build a wk crawler your looks good |
| | #3 |
| Pebble Pounder Join Date: Jun 2007 Location: somewhere
| That thing is super wide. It'll probably look more proportioned once you get it stretched. Good start. |
| | #4 |
| I wanna be Dave Join Date: Jan 2006 Location: CA
| | #5 |
| Well i actually like the wideners an dte route i am going they will be fin. i am not comp crawling. i just want a fun crawl/ trail rig. but your right it is pretty wide. they may not stay not sure yet. I am getting the 80s chevy pro line body for it. the 19 in version. its 7 in wide, just want to make sure my wheels clear it |
| | #6 |
| Quarry Creeper Join Date: Jan 2008 Location: Edmonton, AB
| Reminds me of full width rockwell 2 1/2 ton axles on a blazer. |
| | #7 |
| Well i am waiting on my carbon fiber to arrive so i can cut my chassis.. Links are on the way so i am getting closer.... Couple questions... 1. do you run the foams or not in the tires? My other trucks i didnt but not sure on this one. and i saw someone had the tranny on its side, i like the idea is there any side affects from this? |
| | #8 | |
I haven't noticed anything negative assocciated with clocking the motor. I don't like the idea of just laying everything over because it ends up so wide. A lot of guys have the motor hanging out the side of the chassis waiting to get hung on a rock. | |
| | #9 |
| Ok I am gonna ask a silly question, what is clocking? Personally i think having the motor/tranny laid down is to wide to plus the angles of the driveshafts are off and look lik they will bind. Just my 2 cents |
| | #10 |
| Rock Crawler Join Date: Dec 2007 Location: USA
| can u post a pic of it facing the came like the 2nd pic just not flexing? |
| | #11 | |
| | #12 |
| | #13 |
| ok thanks, i am not sure i like that though. Seems like the motor would get hung up on something |
| | #14 |
| I didn't have any problem with it in the stock chassis. The body covered it so anything that would've caught the motor just slid over the body. In the new "manta" chassis, it doesn't even stick out. Either way, it's a lot better than just laying the entire tarnny and motor on it's side and having the entire motor hanging off the chassis. Check my thread for more pics. |
| | #15 |
| what is the purpose of clocking the motor? |
| | #16 |
| | #17 |
| Definitely just to lower the cog. Maybe to make a more compact package? You gotta get rid of those wideners. think it would be too wide even if you ran 40 series. Last edited by smcurry83; 02-24-2008 at 06:44 PM. |
| | #18 |
| got a question how do you moutn the servo on the axle with out it hitting the shocks ? I built a axle/ servo mount but with the servo in it the thing hits the shocks.... |
| | #19 |
| thx man..it doesnt flip as easy with the wideners does it? and when u go up something side ways does it roll as easy? |
| | #20 |
| With-out seeing pics of the mount and where the servo hits the shocks, I can only guess. Try mounting your shocks on the outside of the lower shock mount instead of the inside. You should be able to make it work. |
| Thread Tools | |
| Display Modes | |
