03-18-2008, 03:34 PM | #1 |
Newbie Join Date: Oct 2007 Location: Martinez
| Tight?
I am in the process of doing the crawler conversion like on HPI's website, can I use the stock pinion with the 96t spur gear? Right now I don't have the pinion that they used, still waiting for it to come in the mail. Thanks, |
03-18-2008, 05:32 PM | #2 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
You can, but you'll notice an even bigger difference with the new pinion.
03-18-2008, 06:16 PM | #3 |
Newbie Join Date: Mar 2008 Location: Austin
has anyone had clearance issues with the 96t spur? Mine likes to rub on the plastic cover a little. it doesn't cause much drag if any but it bothers me...
03-18-2008, 06:21 PM | #4 |
Just take the cover off or clearance it with a Dremel and drum sander.
03-18-2008, 06:34 PM | #5 |
Ok thanks for the reply. I notice that it is hard to turn, could be because of the motor but im not sure. The only electric motors I have used is the novak brushless motors and not sure how hard the brushed motor would be to turn over. |
03-18-2008, 06:36 PM | #6 |
Depending on your gear mesh it should be pretty firm.
03-18-2008, 07:21 PM | #7 |
Rock Crawler Join Date: Jul 2005 Location: Rathdrum, ID USA
03-20-2008, 10:57 PM | #8 |
Newbie Join Date: Feb 2008 Location: Canada
I noticed a little rubbing, but I have a 10t steel pinion and by the time I wear the 96t spur down I figure Ill have a nice and perfect groove in the cover for the next spur to spin freely.
