Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > HPI Wheely King
Thread: Anyone broke a CVD yet?
Old 03-22-2008, 04:10 PM   #1
Default Anyone broke a CVD yet?
I have had the cvd's for a while now, I installed them in the rear about 8 or 9 months ago. I just got around to installing them in the front axle just a couple weeks ago. (havent had much time to play) After building Goober, during my 2nd run, I somehow managed to break a CVD. It was the passenger front. I have replaced it with a stock dogbone for now. Well needless to say, I have since broke 2 stock dogbones within the last 5 or 6 outings (past 3 days). All of them are breaking on the passenger front. After I broke the CVD, my Mamba Max & CCBEC showed up from JRH. I put the new goodies in and it ran fine for the first 2 runs. After that I broke the stock dogbones.
My set up I am running is a:
Mamba Max
CC BEC
JR z9000t Servo
7 cell MPI hump pack
R2 Trans
RC Guy diff lockers
CPE 12-14mm 3/4" wideners
RC4WD 3.2 Truescale beadlocks
Hpi GT tires
Any ideas on why the CVD would break. It didnt snap it at the machined down end like on the stock dogbones, it broke the pin out of the axle cup, not the stub through that goes through the wheel and c-hub. I did a search on axle breakage and found a bunch of threads but none addressed a broken CVD. I now know how to fix the problem to keep from breaking the stock dogbones, but I would like to see if there is any rhyme or reason why I would be breaking CVD's, or if anybody else has broken them.
Is there any axle shafts that are stronger than the cvd's?
Thanks for the help fellas.
TONKA TOY is offline   Reply With Quote
Old 03-22-2008, 06:08 PM   #2
nigels_world(Sam) and myself have both broken CVD's here in AZ. Sam with his super awesome welding skills fixed both of ours and haven't had a problem since(welded the ends of the pins to the cups). I did recieve a new CVD from RCP after sending them pictures and info, no questions asked....wound up getting that one welded up too.
I'm not running a massive amount of power either, 45t, 96/15 gearing, Rooster Crawler, WK tranny...I do get kinda stupid sometimes with the wheel speed though..
joemomma95 is offline   Reply With Quote
Old 03-22-2008, 06:49 PM   #3
Yea...I broke the same one...front passenger side... I'm running a r2d with 9t pinion,mamba max, locked .... I have tons of power litterly twisted my crawler on one tire.. Lol
how does rcp deal with getting the cvd replaced?
Thanks
blakeski is offline   Reply With Quote
Old 03-22-2008, 07:30 PM   #4
I've broken 3 cvds, one snapped the outer where the threads start in a nasty fall, the other two sheared the pin out of the cup. They're definitely stronger than stock, but they're not indestructible. I think they just won't hold up to the abuse of those big tires you run on goober. The first one I broke got warrantied, the last too I've had to buy:-(
chrisjlittle is offline   Reply With Quote
Old 03-22-2008, 07:33 PM   #5
I haven't even broken my stock axles yet, and I am running tons of power. I'm running a 3020-14 Scorpion outrunner, with a Sky One esc, on 10 cell 2000mah batteries, going throught an AX-10 trans.
Toph is offline   Reply With Quote
Old 03-22-2008, 09:04 PM   #6
Here's a thread I made on this topic 3 months ago:
Broken MIP/RCP CVD
MetalMan is offline   Reply With Quote
Old 03-23-2008, 05:37 PM   #7
I am not running the swamp kongs, i was running the HPI GT's. I have maybe 5 minutes of runtime total with the swamp kongs. But i sent a message to info@rcpcrawlers.com, so we will see what happens.
Thanks guys for all the info and all the links.
Old 03-23-2008, 05:59 PM   #8
Keep it real
Tanis's Avatar
Those axles aren't designed for that big of a tire I broke the stock dogbones in my WK axles so easily with 2.2 mudslingers, I got rid of the axles.
Tanis is offline   Reply With Quote
