04-15-2008, 03:26 PM | #1 |
Pebble Pounder Join Date: Jan 2008 Location: Mission, BC
| Locker = Dust. JB Weld = Sucky. 4 months of abuse and the thing let go, crack the chunk open and powder falls out. Apparently JB Weld doesnt bond to aluminum that well. Last edited by EHeye; 04-15-2008 at 03:32 PM. |
04-15-2008, 06:14 PM | #2 |
Rock Crawler Join Date: Apr 2007 Location: St. John's
Looks like its time to drop the RCGuy a line to order some diff locks: http://www.rcguy.com/index.php?main_...products_id=26 They're not too far away - just over in Victoria. I've been using the diff locks for close to a year now with no issues whatsoever!! |
04-15-2008, 07:05 PM | #3 |
Rock Crawler Join Date: Dec 2006 Location: Sierra Vista
Had the same thing happen to my JB locker. I don't know if I didn't get enough in there or what but it didn't take long to make it an open diff again. I bought the lockers off of TCS and haven't had a problem since.
04-16-2008, 12:56 AM | #4 |
Newbie Join Date: Apr 2008 Location: northeast georgia
this is what i got: https://www.ssl-stormerhobbies.com/c...n=STRSTA30440S works great. no reason to buy jb weld when these only cost 10 bucks. |
04-16-2008, 12:01 PM | #5 |
I went and got 2 Axial lockers. 10.99 a piece Put the front one in, now I just need to put the rear one in.
04-16-2008, 12:52 PM | #6 |
Quarry Creeper Join Date: Nov 2007 Location: Alberta canada
My JB weld has beein holding up for a while now. I guess you suckers just don't know how to "weld" haha.
04-16-2008, 12:56 PM | #7 |
Quarry Creeper Join Date: Jun 2007 Location: Sacramento
did you use the puddy stuff or the liquid JB?? I find the puddy stuff is hard to mix properly. If it's not mixed perfectly, it will degrade over time, but I've been running the puddy type with no problems so far (9+ months).
04-16-2008, 02:07 PM | #8 |
It was the 2 tubes stuff, black and a red one. It held great for the abuse that it took, but it totally makes sense why it let go. This stuff doesnt fuse to aluminum, I could chip it all off inbetween the teeth of the spider gears. But it sure stuck to the middle shaft.
04-16-2008, 02:43 PM | #9 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
you guys need to learn how to do it properly. I have jbed diffs in my tlt, wheely king, and clod and have never had any problems with any of them. you need to have more than just jb between the gears for it to be permanent. I fill the whole diff with it . I basiclly make the diff into a spool. The only part you don't want jb in is the holes that the axle shafts go in. If you do it like that you will never have a problem, and you get a little extra weight down low were you want it. |
04-16-2008, 02:45 PM | #10 | |
04-16-2008, 03:38 PM | #11 |
Rock Stacker Join Date: Jan 2006 Location: CT
Hell I hot glued my diffs so they would act more like detroits. Just fill it...everything...every cranny you can possibly imagine. Also it really helps to soak the gears in brake cleaner etc. Or if money isn't an issue sink 10 bucks into aluminum lockers. Personally even with hot glue I beat the living daylights out of my WK axles with no less then full possible performance.
04-18-2008, 11:50 PM | #12 | |
04-19-2008, 10:33 AM | #13 |
Rock Crawler Join Date: May 2007 Location: floriduh
The rcguy ones I have bought were crap, spun out two sets, and the Went to th eones from strc(axial) much better.
04-19-2008, 10:40 AM | #14 |
Quarry Creeper Join Date: May 2007 Location: Brenham, Tx
2 part epoxy with the syringe. best locker ever.
