| | #1 |
| Quarry Creeper Join Date: Sep 2007 Location: Duchesne
| what can I do to make my wheely king crawl better. I want to keep the stock chassis on the truck I have locked both front and rear diffs extended the wheelbase to 12.5" and put a sidewinder esc and 55t lathe motor in the truck. i also have proline 2.2 moab tires on it. but is there something else i could do to make it crawl better with the stock chassis? thanks |
| Sponsored Links | |
| | #2 | |
| I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
move the battery location to the front axle and lower the ride height, also turning the chassis around will help | |
| | #3 |
| SCALE PERFORMANCE PARTS ![]() Join Date: Oct 2007 Location: College Station, TX
| High clearance links & link mounts Better tires Gearing lower the cog by lowering the body as it sits on the chassis axle mounted servo Better turning radius dig setup weighted front axle weighted wheels I've done all of those things to mine. You can check it out on my website Last edited by Locked Up; 05-22-2008 at 08:20 PM. |
| | #4 |
| well I got the better tires down, and I didn't move the battery to the fornt but I added weight to the front of the truck that weighs the same as the battery and i have put weights in teh front and rear tires. but what do you mean be decreased turning radius? and I want to get a dig setup but who has them? |
| | #5 |
| Quarry Creeper Join Date: Nov 2007 Location: barre
| getting the servo over the axle will make a huge difference in steering also a different chassis all together would be your best be the cog on the stock chassis is too high and spending money to get it to crawl better would just be a waste just my 2 cents i wouldnt worry too mich about limiting steering the stock knuckles limit it already imo |
| | #6 | |
The turning radius ... I mean make your rig turn in smaller circles so it is more nimble. High angle front shaft & knuckles are what people usually do, or you can trim your stockers like I did. I'm not saying you need to limit it, I'm saying you want to increase the throw of the knuckle without anything binding. VF is working on a dig unit but until it becomes available you options are to buy a new chassis and an AX10 trans or to make a homebrew one: http://www.noeither.com/WK/tech/dig.php Last edited by Locked Up; 05-22-2008 at 08:19 PM. | |
| | #7 |
| Rock Crawler Join Date: May 2008 Location: ************************ Why crawl, when you can just jump up there?!
| trade it in! |
| Thread Tools | |
| Display Modes | |
