Thread: brake line
Old 06-17-2008, 04:15 PM   #1
Default brake line
i seen that someone on here made links that were made brake line and i was wondering what size and how to do it because i have3/16''x20'' 4.7mmx50.8cm thanks
grizz is offline   Reply With Quote
Old 06-17-2008, 04:34 PM   #2
For my links on my comp rig I use 6-32 allthread sleeved with 1/4" brakeline. It works really good, I have yet to break a link and I have been running them for about a year.
Shaun is offline   Reply With Quote
Old 06-17-2008, 04:40 PM   #3
I use 3/16 brake line... the inner hole is the perfect size to tap with a 6-32 tap, then thread the 6-32 rod into the brake line and finish it up with some Traxxas rod ends
4u2nv is offline   Reply With Quote
Old 06-17-2008, 06:04 PM   #4
ok thanks ill try that and think u could get some pics of it and how u done it?
Old 06-18-2008, 01:23 PM   #5
can you get that at lowes cause im goin there today?
Old 06-18-2008, 05:47 PM   #6
I also used 6-32 allthread and 1/4 brake line. If Lowes doesn't have what you are looking for try your local Napa, thats where I picked mine up.
Lawlessjr is offline   Reply With Quote
Old 06-18-2008, 06:42 PM   #7
Patterson Crawler
A_Jeeper's Avatar
I wish I knew that. I got 1/4 alum tub from tower hibbies and taped it with 8-32. They are working great. I will have to looking into brake tub for the tuber I'm slowly working on.
A_Jeeper is offline   Reply With Quote
Old 06-23-2008, 09:33 PM   #8
ok i got the 6-32 but i got screws cause instead i looked at walmart cause im lazi like that and didnt remeber u said that u used the 1/4 and i have
3-16 will that still work?
Old 06-24-2008, 09:18 AM   #9
MetalMan is offline   Reply With Quote
Old 06-24-2008, 10:35 AM   #10
sourdojack's Avatar
If your going to make links with all-thread I would suggest buying 1/4" round stock delrin (black or natural) and drill out the center and then slide the allthread through it. It slides way better than brake line on the rocks and is plenty strong... On mine I used 8/32 stainless allthread with Revo rod ends.
sourdojack is online now   Reply With Quote
