Thread: WK Axial Hybrid
Old 10-17-2008, 02:05 PM   #1
Default WK - Axial Hybrid??
This is the start of my WK rebuild. I reached a point where the stock chassis was too inhibitive. I wanted to lower the center of gravity, move the motor down & forward and allow room for the motor to run smaller pinion gears. I achieved this by using two clocked motor plates. Detail shots are toward the bottom of the images. Although I haven't bought it yet, the design is based on a lipo sized battery. The intent of the build is to perform very well but maintain a somewhat scale Jeep look. I built in some adjustablility to the chassis with the intent of building another once I dial everything in.
Specs:
WK motor w/ 15t pinion
WK trans with 96t spur & 12t pinion
WK radio and rx
CC Sidewinder ESC
CC BEC at 6V
JR Z650M steering (no dig yet)
WK axles locked with RCGUY lockers
Custom links using Dubro ends, 6-32 all thread & 1/4" x .049 alum. tube (Front Uppers are bent Traxxas links)
WK wheels & tires - cut, weighted, narrowed & enlarged air holes (See pic below)
STRC chassis crossmember
WK Front Shocks - Semi-Droop with 1/2" uptravel - 45 wt. oil
WK Rear Shocks - Droop - 45 wt. oil
HPI Jeep body with custom rocker guards (See pic below)
Near Future:
Lipo
Proline Flat Irons with beadlocks
http://Click the image to open in full size.
Brip is offline   Reply With Quote
Old 10-17-2008, 02:33 PM   #2
..........i am also (soon) doing a wk project, and im wanting to use the flat iron tires, wat beadlocks are you going for?
arow884 is offline   Reply With Quote
Old 10-17-2008, 02:50 PM   #3
I am trying to keep costs down, so I was thinking Proline Eight Shooters. I am going to take more pictures this weekend of what I am currently running. Once I do that you will see my current WK tires, which work very well. I've used Moab's and I would say that my tires work better in dirt and mud, almost as well on rocks, but nowhere near as well in wet conditions.
Old 10-20-2008, 09:50 AM   #4
Default Updated
I updated the thread with current pictures.
Old 10-21-2008, 01:11 PM   #5
crawl rookie's Avatar
What´s Axial about the great looking crawler
crawl rookie is offline   Reply With Quote
Old 10-21-2008, 01:55 PM   #6
Default Axial? Where?
The first thing I did was build the clocked motor plate / tranny setup. When I got finished I realized that I was getting close to the width of the Axial Scorpion. So, I went to the LHS and did some measurin'. I was 5/32" narrower than the Scorpion. So I decided to just make it the same size so that I can use an aftermarket skid plate. Which I bought the STRC aluminum part.
In other words the chassis and it's link connections are now the same/similar to the Axial.
Thanks for the props.
Old 10-21-2008, 02:25 PM   #7
UUhm that doesnt make it a hybrid, do you know what a tlt is?
This this has nothing to do with the axial
Old 10-21-2008, 03:24 PM   #8
No. It has nothing to do with a TLT.
I am using some chassis spec's from the Axial Scorpion and an aftermarket part specific to the Scorpion.
Hybrid is a term used in many genres including plants, bicycles and cars. 'Hybrid' may refer to something TLT related but I am not referring to it.
Old 10-21-2008, 04:28 PM   #9
Prick
rambuller84's Avatar
This has no Axial parts, so it's not a hybrid. It's a very nice truck, but nothing about it is Axial based.
rambuller84 is offline   Reply With Quote
Old 10-22-2008, 07:36 AM   #10
Okay, Okay, Okay! Although I could replace my chassis with a stock Axial chassis in an evening, if you can get past the 'hybrid' title, than I am willing to also. I actually changed the name of the title, slightly.
I think that I've done a few things that I haven't seen others do to their WK's which I believe would be more interesting to talk about. Namely, the motor / transmission mount and the rocker guards.
Again, thanks for the props
