10-27-2008, 08:58 PM | #1 |
Rock Stacker Join Date: Nov 2007 Location: fort collins
| WK Widow chassis problems
I really need some help with this problem. I built a drooper widow chassis to replace my old low profile version, but now I have about .5 inches of clearance with a droop setup My question to you is "How can I get a higher ground clearance without drastically changing how the rig handles?" Here are a few pictures of the rig just to show you what i'm up against. As always, all help is greatly appreciated Here's why i'm skeptical of going to a sprung setup |
10-27-2008, 09:40 PM | #2 |
Rock Crawler Join Date: Jul 2005 Location: Rathdrum, ID USA
How long are those shocks? They look pretty short...
10-27-2008, 10:08 PM | #3 |
Rock Stacker Join Date: Feb 2008 Location: Minnesota/Wisconsin
the only way to get your ride height up is to make your shocks longer, I would go back to a sprung/semi-droop style shock. Otherwise, if your set on using the shocks set-up like that, you will have to have a shorter wheelbase
10-28-2008, 09:58 AM | #4 | |
To answer themerc's question, these are aftermarket tmaxx shocks. | |
11-15-2008, 12:27 PM | #5 |
Rock Stacker Join Date: Sep 2008 Location: cumbria
id turn the lower links round as well so the bent part is at the axle end i had same set up on mine an cog was real low so turned em round an it lifted it up might not be that tho just a thought |
11-15-2008, 11:57 PM | #6 |
Quarry Creeper Join Date: Aug 2008 Location: iderho
Go with some longer shocks. Other than that, it looks good |
11-16-2008, 08:47 AM | #7 |
Pebble Pounder Join Date: May 2006 Location: willows
11-16-2008, 09:23 AM | #8 |
First...make sure you're not longer than a 12.5" wheelbase. If you are good at 12.5", then your shocks are too short. Having the links straight or bent makes no difference. |
