11-19-2008, 11:12 AM | #1 |
Rock Stacker Join Date: Nov 2007 Location: fort collins
| strange stock electronics problem
i keep getting this problem when I'm out crawling, I'm using a tq3, and a 3 channel receiver, towerpro 995 servo, and stock esc. The problem I am having is that sometimes when I'm crawling, everything freezes up on my truck, motor and servo. Whenever it happens, it seems that my servo is at full lock. This problem goes away when I lift the truck so that none of the tires are touching the rocks, and the servo goes back to center, and the motor returns to regular running. This is particullary strange because I tought it was my servo, so I replaced my servo, and the problem is still present. I'm now wondering what the hell is going on with my electronics. Any help would be appreciated |
11-19-2008, 11:41 AM | #2 | |
Newbie Join Date: Jan 2007 Location: St.Louis
You might try a new speed controller with an external castle BEC. Quote:
11-20-2008, 03:44 PM | #3 |
Pebble Pounder Join Date: Feb 2008 Location: Los Angeles, CA ( South Central )
i had something similar happen with one of my rigs. The Airtronics Servo i was running on my WK would glitch and lock to one side. I was using a futaba TX and found that switching it to the TQ3 remedied the problem. I also remember dropping that old TX in the water so maybe thats what messed it up. Try changing it out for another one. I am running a rooster crawler and a Novak 55 turn motor. Good luck. |
11-20-2008, 03:49 PM | #4 |
Rock Crawler Join Date: Aug 2007 Location: Dela-where?
i had a similar problem with a high torque servo on stock esc. i bet its the bec. |
