05-03-2009, 03:07 PM | #1 |
Quarry Creeper Join Date: Aug 2008 Location: iderho
| Drive shafts
Is this a stock replacement or is it for longer suspension? http://cgi.ebay.com/Wheely-King-STEE...ayphotohosting |
05-03-2009, 03:09 PM | #2 |
05-03-2009, 03:29 PM | #3 |
Quarry Creeper Join Date: Feb 2008 Location: Irvine KY
First is stock wb, second should be longer, |
05-03-2009, 03:34 PM | #4 |
Ill give em a try then, if not. Oh well Edit: It says stock replacement in the desc. so i assume they are stock length. Nevermind... What do you reccomend for shafts? |
05-03-2009, 04:29 PM | #5 |
Quarry Creeper Join Date: Apr 2009 Location: Akron, IN
I cut down some Revo Driveshafts to fit the King. They're thicker and just all around bigger....shouldnt break (crossing fingers) Havnt tried them out more than about 10minutes....held up thus far. BTW: I was sitting at a 12.5" wheelbase, but going for a scale look, shortened her up to about a 11.5" wheelbase...they fit nice.
05-03-2009, 05:42 PM | #6 |
I used traxxas on mine, cant remember the part# but they worked just fine |
05-03-2009, 05:44 PM | #7 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
How long is your wheelbase? If you need shafts look at TCSCRAWLERS.COM they have all you need and then some! If your wb is close to 12.5 you should get these. I have used them on both my wk's for a while with no breakage. Cut a 1/4 inch off both pieces if wb is 12.5 http://www.tcscrawlers.com/4951x-Hal...4-p-16294.html |
05-03-2009, 05:55 PM | #8 |
WB will be around 12.5 So those will connect straight to the WK yokes? |
05-03-2009, 06:03 PM | #9 | |
For a 12.5 wb take a hacksaw or dremel and cut 1/4 inch off each end that slides together. Or they will be to long and bind under compression. The good thing is you have a lot of surface contact in the shaft and it makes them plenty strong. I am running a 18 turn motor on lipo on one king and is holding up great> | |
05-03-2009, 06:05 PM | #10 | |
Im using the concept that billet works is using with the motor facing the transmission so im excited to get it running. | |
05-10-2009, 12:06 AM | #11 |
Rock Crawler Join Date: Jan 2007 Location: San Clemente, CA.
those traxxas shafts that rottenbelly posted are what I use. They hold up well to brushless
05-10-2009, 11:40 AM | #12 |
I might go with a 454 puller so im sure they will hold up Thanks guys |
06-26-2009, 08:55 PM | #13 |
RCC Addict Join Date: Dec 2008 Location: pullin somebody else out of a mud hole
i was told to use stampede axles they hold up well to crawling
06-30-2009, 08:21 AM | #14 |
Newbie Join Date: May 2009 Location: havelock
i went all out and got punisher shafts from rc4wd and they are bullitt proof along with there longer links and 3 link all bullitt proof but those shaft cant be broke brushless and mad binding from a under cut did nothing but scratch so yeah worth the 40 bones each
07-05-2009, 05:12 AM | #15 |
Newbie Join Date: May 2009 Location: Newcastle Down Under Aus
E savage are also good you just have to open up the uni ends so they will fit over both the g box output shaft an diff pinion i used an old soldering iron be sure to test fit them fist so ya know how much material to take out
07-06-2009, 05:17 PM | #16 |
I joined the Band! Join Date: May 2009 Location: Palm Bay
If I extend the wheelbase by 2" overall to 11.5" would I need new shafts?
