Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > HPI Wheely King
Thread: Length of Front and rear extended arms ?
Old 05-16-2009, 02:40 PM   #1
Default Length of Front and rear extended arms ?
What is the length of the front and rear carrier arms when you extend them for the crawler build that HPI has done the editorial ? I am using different ends that they used so the all thread and tubing length does not matter . I would like to know the distances between the eyelets for the front and the back.
Thanks,
Raz
RazBarlow is offline   Reply With Quote
Old 05-21-2009, 02:48 PM   #2
Would someone be so kind as to check the length of these arms ? My son is getting antsy . It look like in one of the pics for the build it might be 14 CM but the pic is at an angle.
I just need to know the center to center distance of the front and back arms .
Thanks again,
Raz
Old 05-21-2009, 03:43 PM   #3
Just jump it!
rottenbelly's Avatar
5.5 inches eye to eye with stock chassis will give you a 12.5 wb!
rottenbelly is offline   Reply With Quote
Old 05-21-2009, 04:20 PM   #4
5.5 in. on the front and the back or is the distance different ?
Old 05-21-2009, 04:46 PM   #5
Just jump it!
Its the same. on both links front and back.
