Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > HPI Wheely King
Thread: Wheely king 2.2 tral rig
Old 05-22-2009, 02:59 AM   #1
Default Wheely king 2.2 tral rig
Gday fella's this is my wheely king ive built for the 2.2 trail Aussie comp scene it runs a home custom built chassis to keep the C.O.G low. Suspention wise im using Integy full droop intersprung shocks an bent lowwer link arms with crawler king plastic uppers soon to be custom home made billet alloy. Diffs are HPI locked WK item's with custom billet alloy servo mounts with a 24 kg Hitec Servo upfront an a 10.4 in the rear also with custom billet alloy staering arms. Gearbox has had upgraded steel gears fitted although is about to be upgraded to an R2 Dig for even better C.O.G. Engine an ESC is a 55T Integy controled by a Tekin Fxr an 6 ch Hitec reciver an Stick Radio.Rims an Tyres are HPI 8 shooter beadlock rims fitted with HB Rovers.
MUDRAT is offline   Reply With Quote
Old 05-22-2009, 04:17 AM   #2
looking good. im in NSW too, might see you at a comp one day.
collins_12345 is offline   Reply With Quote
Old 05-23-2009, 01:03 AM   #3
Thanks Col its Corey its changed a bit since the Musso comp eh
Old 05-23-2009, 02:09 AM   #4
oh rido, yeah it looks good, is this kurts old wheely king or another one?
Old 05-23-2009, 05:44 PM   #5
Na kurts old one i moded its now a totaly differant setup for limmited the one in the pic is the one from the Musso comp but with a new custom chasis its based on the one from kurts old one but stretched out further in the shock mounts an narrowed down a bit
Old 05-25-2009, 03:29 AM   #6
ohok
i got my axial im going to run in limited and im building my wheely king for trail at the moment, theres a thread in here of it, i dunno if it is gunna be very good though.
Old 06-03-2009, 04:16 AM   #7
Just a bit of an update ive now moved the motor down lower an towards the front for beter C.O.G an weight distrubution an have done a 4 link setup here's a few pic's
Old 06-05-2009, 09:24 AM   #8
Here's a few pic's of it fully completed with a new painted shell an colour coded beadlocks.
